Is the MRX-3100 ESC/receiver good for 1S use? Random question, the title says it all! This actually isn't for an off-road project :p (It is pretty scale, though) But I need both an ESC, and a spektrum receiver to power a small motor at 1S voltage, and the 2-in-1 unit from the micro crawler looks perfect! The ESC part is easy, but the spektrum receivers, in my experience, don't like much below even 5.5V... The stock NiMh is 4-cells, if I remember correctly, which is pretty much 1S territory, so I don't really know... I used to have a micro trail trekker, but only ever ran it on 2S, so I can't even answer my own question! Also: if anyone has one of these units kicking around and don't need it, I want it! (preferably cheap, as this "small" motor is still larger than the micro trekker/crawler motors, and I remember it running hot with my hand-wound 90T, so... it might go poof) Thanks :) |
Re: Is the MRX-3100 ESC/receiver good for 1S use? Absolutely no problem,i run my trekker on 1s sometimes.i like the way you have more control over the throttle. |
