10-09-2014, 07:42 PM | #21 |
RCC Addict Join Date: Jan 2011 Location: Forest Floor
| Re: 3D Printed Rims Now Available
I hear ya, I prefer the wagon wheel myself. haha This was for someone else. But I posted it because of the tire. It's challenging to do tires, but mostly just figuring out the pattern. Interestingly enough that is a 1/25th scale semi dually wheel (22.5") and a Mud Grappler tire (35").
10-10-2014, 08:54 AM | #22 |
Need a little help. |
10-10-2014, 10:17 AM | #23 |
Rock Crawler Join Date: Oct 2004 Location: The thumb
2mm measured from an actual urethane tire..
10-10-2014, 10:32 AM | #24 |
Ok 2mm for the right side measurement, but the left side should be more like 6mm. Thanks!
10-10-2014, 11:26 AM | #25 |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
left 8mm Edit: Just checked a few more tires 9mm was wrong it is 8mm.. I think a 12mm wide rim 3mm back space 3mm offset Thats what i run on the micro dirtpro Last edited by chevy55; 10-10-2014 at 12:18 PM. |
10-10-2014, 11:35 AM | #26 |
Thanks! oh I just thought, what offset for this? Rather than try to reference stock rim offset, just assume a .06" plate centered on the rim. How much offset from there to the face of the 7mm hex hub on the axle?
10-10-2014, 01:20 PM | #27 |
On the tractor wheels I made the face of the hex would be about 8mm from the outer edge of the wheel. That kept it as narrow as possible without scrubbing to bad at full turn.
10-10-2014, 03:19 PM | #28 |
Here is the rim only. There will be a second part that glues on with the hex part and offset. |
10-10-2014, 03:30 PM | #29 |
oops I missed the edit. I will narrow the rim 1mm, push the face back 3mm, and see about adding the hex hub. |
10-10-2014, 03:40 PM | #30 |
Rock Crawler Join Date: Dec 2013 Location: Nevada City
I would personally like to see something along these lines for a wheel.
10-10-2014, 07:20 PM | #31 |
Can do. Here's where it is now. May need more offset. |
10-10-2014, 10:08 PM | #32 |
| Re: 3D Printed Rims Now Available |
10-11-2014, 05:10 AM | #33 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
I know sumo axles are faster but im just going for looks... more so as im not gonna mud it... Sent from my Samsung Galaxy Note 3 |
10-11-2014, 08:08 AM | #34 |
How about this Chevy? |
10-11-2014, 09:52 AM | #35 |
Personally I like the first offset, but that's because I'm running 1/20 bodies and I like the wide stance. Would it be to much to offer both offsets? That way you could chose depending upon your rig.
10-11-2014, 12:31 PM | #36 |
No trouble to offer different offsets. I'm working on the other rim design too.
10-11-2014, 02:40 PM | #37 |
Here's the spoke'd version, minus the john deer beadlock. It has the same offset as the one directly above. I can add to it as well. I will draw it up. Last edited by Fungi; 10-11-2014 at 04:58 PM. |
10-11-2014, 07:45 PM | #38 |
they look nice.. i dont like the blingish they give.. but that is me... I like the oh they look ghetto where u took the tires off your tractor and put them on your truck... U know how they did it in the 80's..... LOL
10-12-2014, 06:46 AM | #39 |
My job was just to recreate the rim. ;) It's pretty close. |
10-12-2014, 07:55 AM | #40 |
Helluva job on both Jim they look great! How well do you think the material will hold up to some serious power? |
3D Printed Rims Now Available - Similar Threads | ||||
3D printed Micro Crawler Rims | Fungi | Vendors Tires and wheels | 47 | 01-07-2017 12:48 PM |
a few 3D printed accessories | DRW-FJ40 | Scale Accessories | 14 | 07-16-2014 10:28 PM |
Need decals printed.... | Biscuit | Paint and Body | 4 | 12-04-2009 05:13 PM |
printed styrene | punkuup5150 | General Scale Talk | 6 | 11-02-2009 10:29 PM |
