10-12-2014, 08:47 AM | #41 |
RCC Addict Join Date: Jan 2011 Location: Forest Floor
| Re: 3D Printed Rims Now Available
Honestly not sure, I don't have any go fast rigs. The material is very strong, and the tire should take most of the impact. I think they should be ok. The first design will be stronger than the spoke version.
10-13-2014, 04:52 PM | #42 |
Pebble Pounder Join Date: May 2007 Location: Dirty Jerz
| Re: 3D Printed Rims Now Available |
10-14-2014, 10:46 AM | #43 |
Here are some other images. The Tractor Tire rim with eight holes and extra hardware. A combination stock style rim with 1/8" offset and integrated PVC style bead lock. Prototype! I don't know if the screws will strip out. The 1/4" offset Thompson Classis II with fake bead lock. |
10-14-2014, 12:07 PM | #44 |
Rock Crawler Join Date: Dec 2013 Location: Nevada City
I'm digging on those Thompsons!
10-15-2014, 09:47 AM | #45 |
that Thompson is sexy
10-15-2014, 11:45 AM | #46 | |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
| Re: 3D Printed Rims Now Available Quote:
I was more worried about exploding the hex mount area with 4s I still plan on picking up a few sets of rims from you. Once my wallet recovers from my daughters 16th b-day Digg'n all the new designs | |
10-15-2014, 11:51 AM | #47 | |
I joined the Band! Join Date: Jul 2011 Location: Philippines
4s.. HOLY COW DUDE!!!! lemme guess sumo axles too!!!!! got a video? know u do | |
10-15-2014, 09:43 PM | #48 |
Pebble Pounder Join Date: Feb 2012 Location: Buffalo
I like that M/T. Can you make it to where a guy could bolt on some of your awesome bead lock rings?
10-16-2014, 12:38 PM | #49 |
Thanks for the good words. I'm going to post a pic of the Thompson in primer today or tomorrow. Yeah Chevy, I know... I been meaning to get a go fast one. And with 4s, yeah they might explode. lol There is a big difference in the width of the fake bead-lock, and one that can be attached with screws. |
10-17-2014, 10:18 AM | #50 |
Here they are. The details came out awesomely! |
10-20-2014, 02:17 PM | #51 |
I added several new rim designs to my Vendor Page. 3D printed Micro Crawler Rims |
10-20-2014, 06:07 PM | #52 |
Pebble Pounder Join Date: Nov 2009 Location: Waterford , PA.
Can these wheels be dyed with RIT clothing dye ?
10-20-2014, 07:27 PM | #53 |
Yes you can. You just have to keep the temperature below 160 degrees F durring the process. I've found flat Tamiya paints also do well even without primer.
10-28-2014, 03:42 PM | #54 |
Here is a picture of the bead-lock rim. It took a couple revisions to get it where it works pretty well. Here is a picture of the three tractor tire rims I printed. I need to narrow the rim about .010" and enlarge the diameter by .030" and it'll be even awesomer! The tire is really nice and soft. Softer than a pencil eraser, but not too soft. I like 'em! I'm behind in drawing rims in 1/4" offsets, but I made progress on my leaf spring chassis today. |
10-28-2014, 05:01 PM | #55 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
Does your rims fit the redcat micro also?
10-28-2014, 08:05 PM | #56 |
Those tractor rims re lookin' good!
10-29-2014, 04:08 PM | #57 |
From what I was able to find they both use the same 7mm hex. The sumo uses a slightly larger nut and stub size. It should work just fine.
11-08-2014, 09:10 AM | #58 |
I couldn't leave the tractor rim alone. I wanted to make it a little more realistic, so I added the raised part in the middle and added a slope to make the outer most edge a little thinner. See the cross-section to see what I mean. This rim design has 1/4" offset, twice that of the first version. The 1/8" offset doesn't really work for the leaf spring chassis, as far as clearance for turning goes. It clears just fine for the stock four link chassis. The original intent "to keep the tires under the body" might not work so well as turning will be limited. I think most will want the 1/4" offset version. I will post images of chassis and tires mounted when I get my other tire order in. I haven't printed this new version yet. |
11-18-2014, 07:05 AM | #59 |
Here's the tractor tire rim if anyone is interested. The dimensional changes I made to the rim makes it fit perfectly. The aesthetic changes make it look a lot better. I can make these available if anyone wants them. Thanks! Last edited by Fungi; 11-18-2014 at 07:24 AM. |
11-18-2014, 08:20 AM | #60 |
Those wheels look good! I'm definitely interested. Are all three styles available?
3D Printed Rims Now Available - Similar Threads | ||||
3D printed Micro Crawler Rims | Fungi | Vendors Tires and wheels | 47 | 01-07-2017 12:48 PM |
a few 3D printed accessories | DRW-FJ40 | Scale Accessories | 14 | 07-16-2014 10:28 PM |
Need decals printed.... | Biscuit | Paint and Body | 4 | 12-04-2009 05:13 PM |
printed styrene | punkuup5150 | General Scale Talk | 6 | 11-02-2009 10:29 PM |
