06-11-2015, 11:18 AM | #1 |
Newbie Join Date: Mar 2015 Location: piermont
| Losi micro crawler ford dump build (with pictures)
My first time using styrene it is 2mm thick and i used a lot of super glue The dump is scaled after an 8X8 dump box on a 1997 ford f450 I was not able to find s ford f450 of f350 a reasonable price so I bought a f150 the body style I ordered a 4.5 crawlerx leaf spring chassis I will be using it at 5 inch Build inspiration 1997 ford Super Duty Custom 4x4 10 lug Wheels I 3d printed dually adapters Started the dump box My CrawlerX 4.5 leaf spring chassis Made some extended drive shart out of carbon fiber and to cut the carbon fiber perfectly square I spun the rod in a drill and cut it with a Dremel as it was spinning I found a Ford model that I am going to use Found this at radio shack and thought it would make a nice plow light Made a mount for the body and added my brushless motor on my flipped transmission i hope to get more weight up front because the weight of the dump body So then i can ass 2 scew to hold it After the body was mounted I painted the really chrome grill I painted the dump box black and started to bend up some styrene rod to make the arm that hold the tarp Added some more bends to the arm and added some tube that the arm will fit in side so it will rotate Added the bracket that will hold the rolled up tarp and I drilled a hole and inserted the larger tube in so the tarp will rolled up smoothly Fit the arm and the tarp Cut the material I am going to use for the tarp Mounted the tarp up Added a hadle Glued a plastic bead on to the handle Added some paint Painted the rest of the box and screwed the side boards one |
06-11-2015, 11:21 AM | #2 |
| Re: Losi micro crawler ford dump build (with pictures)
Here is a running video https://www.youtube.com/watch?v=xdRfIROZwDE |
06-11-2015, 03:14 PM | #3 |
Quarry Creeper Join Date: May 2013 Location: Chino
Dam Creative I like thanks for sharing
06-11-2015, 03:30 PM | #4 |
Nice work man!
06-11-2015, 05:38 PM | #5 |
| Re: Losi micro crawler ford dump build (with pictures) |
08-30-2015, 10:40 AM | #6 |
RCC Addict Join Date: Jan 2011 Location: Forest Floor
I'm sorry for getting sidetracked a couple times. But I finally have the rims you asked me to create. They are available for immediate ordering from Shapeways. Here is a picture of a similar type of rim I just received from them. These are 3D printed in rugged nylon! They take paint very well. You will not be disappointed! Shapeways link. |
08-30-2015, 10:45 AM | #7 |
The front rims are .125" offset, (to make them farther apart) and the rears are -.200" offset, (to make them closer together). If you have a Losi McRC axle it can be used for the rear, and a trekker axle in the front to make it look as realistic as possible. It's not just two rims stacked together... ;) |
09-14-2015, 01:41 PM | #8 |
Thank for the wheels Fungi, they look great I have to get some paint on them and mount them all up. keep up the good work Fungi |
10-12-2015, 12:42 PM | #9 |
12-19-2015, 09:25 AM | #10 |
Losi 1/24 micro scaler Ford 1-ton dump fire wood run https://youtu.be/fNOeLYQf2Uw |
12-20-2015, 09:20 AM | #11 |
I really liked the stop action loading the firewood. Really well done! |
12-23-2015, 12:44 PM | #12 |
12-23-2015, 05:54 PM | #13 |
HobbyMachine and Fungi, very nice!
12-23-2015, 08:32 PM | #14 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
12-24-2015, 07:47 AM | #15 |
Newbie Join Date: Dec 2015 Location: Boise
two nano servos and make one run the tarp. mount it on the side of the dump bed to fold arm over.
01-05-2016, 09:25 PM | #16 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
Great looking build Sent from my iPhone using Tapascrap |
01-07-2016, 10:16 AM | #17 | |
| Re: Losi micro crawler ford dump build (with pictures) Thanks for the support Quote:
Losi micro crawler ford dump build (with pictures) - Similar Threads | ||||
Losi Micro Crawler Blade TMC build | Evilinside | Losi Micro-Rock Crawler | 51 | 09-19-2012 07:51 AM |
BWD Losi Micro Crawler Build pt.1 - Presented by CowRC! | SwedishRC | Losi Micro-Rock Crawler | 0 | 05-18-2012 02:50 AM |
