Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: Losi micro crawler's stock wheel fits directly to trail trecker?
Old 02-08-2015, 08:39 PM   #1
Default Losi micro crawler's stock wheel fits directly to trail trecker?
Guys,
I wish to know Losi micro trail trecker's stock wheels directly fit to the old micro crawler?
The reason is to get trail tracker wheel is tht looks more scale than crappy crawler's one.
There is an issue of hex , stub etc so I want to make sure. I just want to buy the wheels & put it on & run th vehicle. Thanks guys.
lotaloi is offline   Reply With Quote
Old 02-08-2015, 09:34 PM   #2
Default Re: Losi micro crawler's stock wheel fits directly to trail trecker?
You have to put trekker studs in and need a set of hex drives
1tuffmj is offline   Reply With Quote
Old 02-08-2015, 10:08 PM   #3
Why stud is required? Can u clarify by letting pics tht are required pls? R u tlking abt axle stub? Thanks.
Old 02-08-2015, 10:14 PM   #4
Trekker and micro crawler wheels are the same and interchangeable, they also swap with the Redcat 1/24 crawler & rebadged variant, the HSP 1/24 cralwer and rebadged variant, the RC4WD wheels, as well as the few customs for sale by the micro vendors here. The mini QlO wheels are close and the wheel hex is the same 7mm size. The longer trekker shafts, and thicker hexes are to make the stock micro crawler axle wider.
Sent from my Note3
spoo76 is offline   Reply With Quote
Old 02-08-2015, 10:40 PM   #5
Direct fit.
aorquiz is offline   Reply With Quote
Old 02-11-2015, 10:18 AM   #6
There are some neat looking aluminum beadlock wheels available for the miniqlo, any idea if they bolt up?
Edit- those aren't beadlocks, nevermind, the pretty colors just caught my eye.
TownsendTdi is offline   Reply With Quote
Losi micro crawler's stock wheel fits directly to trail trecker? - Similar Threads
BWD Micro Wheel Weight System for the new Losi Micro Crawler! billet works Vendors Market 19 10-18-2010 05:42 PM
