Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: Trekker / McRC Rear Lockout Project
Old 03-26-2015, 08:34 AM   #21
Default Re: Trekker / McRC Rear Lockout Project
Thanks for the encouragement. I made a little progress. I will set up the steering parts for sale sans any chassis. I redesigned the parts so it is no longer required to be glued together. A single 2mm screw holds everything together. It is solid and works great. Here are some images of a 4 link frame using it. I just need to mount the servo and source a larger diameter pushrod, as 0.028" is a little bendy. I will change from styrene to Delrin now that glue is not required. In my chassis example it's using low profile shock/link brackets on the axle assemblies, and I do have a slight bit if binding in the front. I may have to go to a cross member shock mount in the front like in the back.
Menace, lockouts are designed to replace the separate axle, and stub axle, with a single axle, making for a lighter, stronger, simpler assembly. It also slims down the assembly and looks more realistic. In my case I don't have the capability to make the metal axle parts, so I designed the lockout to use the stock axle, and stub axle parts, and just make it a cleaner more streamlined assembly.
Fungi is offline   Reply With Quote
Old 03-26-2015, 05:14 PM   #22
Anxious to see what your plans are for mounting the servo, also i was looking at the front losing axle thinking of what would make it better, and looking at the bulky chubs with the big screws on the top and bottom that hang up on everything, it would be really cool if you could work some of your magic on them, just thinking out loud, keep the great work coming
MikeChino is offline   Reply With Quote
Old 03-26-2015, 06:37 PM   #23
Hi Mike! It's been suggested, but it's not really feasible to make that part with the 3D printer. The shoulder bolts can be removed and replaced with 2mm screws. The problem is the ID of the chub pivots are a hair over 3mm, but all of the sources I have for 2mm socket head cap screws have a head about 3.5mm. Interestingly enough the 2mm screws that hold the servo are perfect with a 3mm head, however they are too long and need to be cut sorter.
Old 03-26-2015, 07:20 PM   #24
I've actually used this mod before. It works well, and adds some much appreciated clearance., as well as cleaning it up nicely!
R.Billy Rob is offline   Reply With Quote
Old 12-08-2016, 05:55 PM   #25
I finally finished this chassis mounted steering servo thing. I mounted the servo in between the frame rails, and connected the .030" pushrod to the stock servo horn. It works great. There's a little flex, so I ordered some .040" music wire for the pushrod. I'm building a 80's bronco crawler to go on top.
https://youtu.be/U8dZBO50OBE
Old 12-08-2016, 09:32 PM   #26
That thing is looking good Jim! I love the steering setup. Can't wait to see you finish this one. You always do great work.
Old 12-28-2016, 05:20 PM   #27
I did some more work on the Bronco.
I got the engine cowl installed and the 351 Windsor wedged in.
I glued in the interior tub and added some reinforcing bars to help hole everything together.
Then I cut the doors off. Next step is to cut the interior tub and tie it all together.
Old 12-31-2016, 04:04 PM   #28
I got the inner tub cut away, and most of the filler pieces installed. I sanded off the bronco emblems and side turn signals on the front quarter panels (rocks knocked them off). I cut away even more on the front wheel wells. Looking forward to making the roll cage.
Old 01-06-2017, 03:44 PM   #29
I putting all the future updates to this build on the Scale Micro page.
Old 06-08-2017, 06:19 AM   #30
Is this link set up still available?
seedburns is offline   Reply With Quote
Old 06-11-2017, 01:55 PM   #31
Attachment 353310
Attachment 353311
Attachment 353312
Attachment 353313
Attachment 353314
Where can I find those wheels?
Inviato dal mio P027 utilizzando Tapatalk
irondog is offline   Reply With Quote
Trekker / McRC Rear Lockout Project - Similar Threads
Anyone have any 3D models of MCRC or Trekker parts? Fungi Losi Micro-Rock Crawler 0 06-14-2012 10:46 AM
Trekker to McRC part compatibility? Fungi Losi Micro-Rock Crawler 4 03-06-2012 11:28 AM
