![]() | #21 | ||
DravTech ![]() Join Date: Aug 2012 Location: Sweden
| ![]() Quote:
Welcome to RCC and crawlers! This forum is almost all you need if you are looking for information about crawlers. It sounds like you have an exciting project in the plans ![]() The 1/18 buggy wheels uses the same hex as the stock RockSta wheels so no need to use any adapters. For 12 mm hexes I have not good answer. Perhaps look more towards the 1/14 or 1/16 buggies (Losi Mini8ight, Carisma GTB etc...)? They might have 12 mm hexes and 3 mm axle stubs. Also no good advice for the beadlocks either. I made some myself but those are more expensive than the RC4WD ones... Quote:
![]() | #22 | |
Quarry Creeper Join Date: Jan 2009 Location: Cerritos
| ![]() Quote:
Wanted to build a Losi MRC, but can't find everything I'd need for a custom build. Looks like everything is just about discontinued. As far as features on the Rocksta, I'm super impressed from what I see online. Even more so with what you've already done to yours. | |
![]() | #23 | |
| ![]() Quote:
I also sell many parts for the MRC if you want a custom build ![]() | |
![]() | #24 |
Quarry Creeper Join Date: Dec 2013 Location: Lancaster
What is required to allow for the use of separate escs front and back to work the axles independently? I've never cared to worry about doing that, until I saw a video recently of what that allows you to do with a crawler! With less than perfect steering that could be a great asset. Sent from my LG-D800 using Tapatalk |
![]() | #25 | |
| ![]() Quote:
But for most it is enough to have a pistol style radio that can handle mixing of 2 esc. Most of the medium, or high end radios has that option. I personally really like the Sanwa MT4. To be able to control the axles independent of each other and have 4WS you need 4 channels. | |
![]() | #26 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
You can have independent control with a pistol grip radio. most people with dual ESCs have that setup, it just won't do simultaneous independent axles which isn't a big deal for most people. As long as there are at least 3 channels and mixing. Mine is set up with a hacked GT3B. For wiring do some searches for dual ESCs or check the electronics section and there should be a few instructions and even diagrams. For mini rock crawlers parts I'd check the Mini section. It had lots of aftermarket support, and I would expect the replacement from vattera (Losi) and the clones like hbx and HSP may have some parts that can swap. As for beadlocks you can take stock Losi mini rock crawlers wheels and some PVC pipe and modify the wheel into a true beadlock.
![]() | #27 | |
| ![]() Quote:
Sent from my LG-D800 using Tapatalk | |
![]() | #28 |
| ![]() You can run front dig which locks the rear axle and drives the front, rear dig which locks the front and drives the rear. You can also have proportional overdrive for the front and underdrive for the rear. So if you for example have it set to 10%, every click of the slider makes the front axle 10% faster than the rear and you can do the same to underdrive the rear. The 3ch button can be used to quickly reset everything to a 50/50 split.
![]() | #29 |
I wanna research this, but I'll start my own thread. Thank you! Sent from my LG-D800 using Tapatalk |
![]() | #30 |
Newbie Join Date: Jan 2016 Location: KS
Dang those cheap kits are so tempting, thanks for the amazing pics.
![]() | #31 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
Does this RC come stock with dig or is that the modifications you did using dual ESCs?
![]() | #32 |
Quarry Creeper Join Date: May 2013 Location: Chino
Bump. I'm almost out of Popcorn.. ![]() |
![]() | #33 |
Moderator ![]() Join Date: Sep 2008 Location: PA
Very cool!
![]() | #34 |
Quarry Creeper Join Date: May 2014 Location: United States
subbed
![]() | #35 |
RCC Addict Join Date: Apr 2009 Location: LA
Anybody know what size hex and socket drivers I'll need for the Rocksta? Thanks in advance! ![]() |
![]() | #36 | |
Quarry Creeper Join Date: Dec 2016 Location: westlerly
| ![]() Quote:
Sent from my SAMSUNG-SM-G920A using Tapatalk | |
![]() | #37 | |
| ![]() Quote:
Sent from my Nexus 6P using Tapatalk | |
![]() | #38 |
The XYS-BL20A is on the far right. The 10 amp version is plenty strong enough and a little smaller. ![]() Sent from my Nexus 6P using Tapatalk |
![]() | #39 | |
| ![]() Quote:
If I can't get metal gears I might not get it anyway. Sent from my SAMSUNG-SM-G920A using Tapatalk | |
![]() | #40 |
In this case they call reverse delay "brake" not having it allows you to go from forward to instant reverse to prevent a rollover on an incline. Otherwise there is stop, a few seconds of delay, then tap reverse again to move. Metal gears are available with searching. I've seen people recently post about picking some up Sent from my Nexus 6P using Tapatalk |
Dravpnir tries to build something small, again... | Dravpnir | Losi Mini-Rock Crawler | 106 | 01-09-2018 10:07 AM |
Dravpnir tries to build something Sporty | Dravpnir | Axial AX-10 Scorpion | 19 | 09-10-2017 07:19 PM |
Dravpnir tries to build something really small | Dravpnir | Losi Micro-Rock Crawler | 7 | 03-11-2015 01:33 AM |
Dravpnir tries to build something small | Dravpnir | Losi Mini-Rock Crawler | 221 | 11-10-2014 02:28 PM |
Dravpnir tries to build something light | Dravpnir | EnRoute Berg | 125 | 04-23-2014 06:01 AM |
