03-24-2017, 09:30 PM | #1 |
Newbie Join Date: May 2015 Location: West Monroe
| How to put massive weight in tires with internal beadlocks?
I have 1.0 wheels and they're internal beadlocks. How can I add ALOT of weight to my wheels? Also... should I run stock foams? I will be running light trails with dirt hills so I need traction since I have low wheel speed.
03-25-2017, 12:09 AM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: How to put massive weight in tires with internal beadlocks?
All the info is the same as when you posted about this in the tire section. It's BBs or wrapping solder around the wheels. As far as foams most people run no foams in the micros unless they have a heavy rig (for a micro) in that case if youre heavy or have larger tires like miclaws or RC4WD scramblers you could try the crawler Innovations micro foams. Either way if your tires are glued or sealed tight with bead locks don't forget to vent the tires. Sent from my Nexus 6P using Tapatalk |
03-27-2017, 10:14 AM | #3 |
Rock Crawler Join Date: Dec 2013 Location: Nevada City
Personally I like using lead tape. It's a 1/4" thick, and self adhesive so it's easy to use. They sell it for tennis players to wrap their rackets in to give them more weight. I want to say it was less than $10 for around 100' of it.
03-27-2017, 10:17 AM | #4 | |
| Re: How to put massive weight in tires with internal beadlocks? Quote:
Now THAT'S more like it!!! thanks for that info!! | |
03-27-2017, 04:33 PM | #5 |
RCC Addict Join Date: Jan 2011 Location: Forest Floor
Many use solder wrapped around the inside of the rim. I have found that because solder is a mixture of lead and tin, the actual weight of solder is about the same as good old copper wire. I like using copper wire because it is safer to work with than lead based solder. You can apply this wire to a stock rim, but you have to dismount the glued on tire at least on one side. Remove the foam and wrap the wire around the inside. I make aftermarket rims that can have extra weight added. I have glue rims and beadlocks. My website and shapeways store links are in my sig if you are interested. This is how I add weight to bead lock rims. This rim uses steel washers to add weight. |
04-26-2017, 04:59 AM | #6 |
Rock Stacker Join Date: Apr 2017 Location: North GA
Fungi I was looking on your store and I see your beadlock wheels but I don't see and beadlock rings. Do you just use the rings from the factory wheels? Thanks.
04-27-2017, 09:49 AM | #8 |
man those look awesome...thank you i will check them out
How to put massive weight in tires with internal beadlocks? - Similar Threads | ||||
Axial Internal Wheel Weight System for 1.9 & 2.2 Axial Beadlocks | Brandon | Axial SCX-10 | 13 | 12-15-2014 10:38 AM |
how to put internal shocks? | qcax10 | Axial AX-10 Scorpion | 4 | 01-29-2012 07:11 PM |
Axial Internal Wheel Weight System for 1.9 & 2.2 Axial Beadlocks | Brandon | Axial AX-10 Scorpion | 22 | 07-23-2010 02:37 PM |
In Comp can you put weight in the tires? | andy27012 | Newbie General | 1 | 01-26-2010 07:02 AM |
I wanna put some LST Tires on with beadlocks but.. | ClodTrasher | Tires and Wheels | 9 | 10-28-2004 02:48 AM |
