Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: What is the closest substitute to the LMRC
Old 04-26-2017, 04:50 AM   #1
Default What is the closest substitute to the LMRC
So I picked up a losi micro crawler that was a mess. Finally got it all sorted out and going as it should and its a lot of fun inside on a rainy day. So now I need to find 2 more micro crawlers for the kids. What is the closest thing to the losi? We are notIt into scale so that doesn't matter. I was looking at the ecx temper which looks like a pretty close copy of the losi. What are your thoughts?
moyoman202 is offline   Reply With Quote
Old 04-27-2017, 09:13 PM   #2
Default Re: What is the closest substitute to the LMRC
The Trekker and Micro Crawler are the best out there. The Temper would be fine for kids. Its not as capable as Losi, but they work fine and are more affordable. Or you could go with the Redcat Sumo, which comes with 4 wheels steering out of the box. The Basher Rocksta is also one that comes with 4 wheel steering out of the box and is affordable. I have heard of some esc issues with the Rocksta. The only issue I have heard about the Temper is limited steering as apparently the wheels tend to hit the upper links if the wheels are turned all the way to the left or right. I think Temper is the best product for what it seems like you are looking for...
cleanandserenesteve is offline   Reply With Quote
Old 04-28-2017, 04:42 AM   #3
Thanks.
Old 04-28-2017, 05:29 AM   #4
There's two Chinese clones that resemble the LMC on banggood.com for less than $100. I don't know how good but they look similar.
The Rocksta is a MOA and I don't think what you're looking for.
Brake Weight is offline   Reply With Quote
Old 04-28-2017, 11:28 AM   #5
Just got one of these from Gearbest last month:
http://m.gearbest.com/rc-cars/pp_462705.html
For £32 delivered, I'm not complaining!
You will need to swap around the ball links and snip some of the springs off the shocks to get better performance.
Not using the stock Rx/Tx/battery so YMMV...
Sent from my Nexus 6P using Tapatalk
jimbo_wa is offline   Reply With Quote
Old 04-28-2017, 02:41 PM   #6
That's one of them.
Old 05-03-2017, 12:12 PM   #7
thanks guys
Old 05-06-2017, 07:37 AM   #8
$33 for now. I figured I'd give it a go for that price.
http://m.gearbest.com/rc-cars/pp_462...?lkid=10114182
Old 05-06-2017, 12:15 PM   #9
Seems like the losi micro is pretty hard to find even used.
Old 05-06-2017, 01:29 PM   #10
They are. Check user Fungi's website out. He had some put back when they were discontinued.
http://lynxmicrotech.com/parts/
Old 05-07-2017, 10:41 AM   #11
Losi Trekker, for sure. Fungi even sells adjustable links so you can shorter the wheelbase If you want it just like the Micro crawler.
LiqrSicc is offline   Reply With Quote
Old 06-13-2017, 11:34 AM   #12
I run a Redcat Sumo Crawler. I love it to be honest. Some mods and I think you're good to go. Its got 4 wheel steer and that is so nice. Only mods I've done are: trim the body, reposition shock positions on chassis, some sticker led weights on front and back. The biggest and best mod have been RC4WD 1" steel beadlock wheels and Scramber tires. The tires (with foams) are great on grip and ground clearance (they are 2.5" tall). Fantastic mod!! I am still running stock aaa'a (Panasonic Omloops). At full charge I am getting 1.5v each and total of almost 6v with 1000mah. I am contemplating the lipo conversion only for power sake but stock is still good imo. Anyway, don't discredit this crawler. Redcat customer service has been very good too. I have had to change out a rear servo and a motor but as much as I run it, that is to be expected.
Also, the Basher Rocsta looks good and has great features like MOA and great price. BUT.....don't get it. I had one and within a few weeks the stock, plastic gears stripped out. I used it so intelligently and this still happened. Hobbyking has metal gears for it but they are forever on back order. Tons of others users have this same complaint. Consider this a sad but true warning.
Last edited by THX_138; 06-24-2017 at 08:17 AM. Reason: Merge, posted minute apart
sethstiles is offline   Reply With Quote
Old 06-14-2017, 02:37 PM   #13
It looks like the rocksta gear set is on fleabay.
https://www.ebay.com/itm/252988377196
R.Billy Rob is offline   Reply With Quote
What is the closest substitute to the LMRC - Similar Threads
So what's with the lurchy nature of the Rockslide? Substitute ... ? TakeOffYouHoser Redcat Crawlers 15 06-15-2014 08:27 AM
HR OB axle replacement /substitute ? jxtreem Tamiya Clod Buster 4 04-12-2012 06:35 PM
motor cleaner substitute tyrod_emmons Electronics 3 04-12-2011 12:15 AM
Substitute battery charger OniTora General Crawlers 0 09-03-2006 11:52 AM
super rooster substitute fuzzhead Electronics 9 12-13-2004 10:12 PM
