Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: Where to find pinion gears?
Old 01-02-2019, 04:24 PM   #1
Default Where to find pinion gears?
Plastic one slips and im having a hard time finding some brass pinion gears. Can anyone point me in the right direction? Just rebuilt my trans with metal gears and new billet case with a PN racing 70T motor and neo magnets and cant put the pinion that's already giving me issues on this bomb proof setup.
balln is offline   Reply With Quote
Old 01-02-2019, 04:32 PM   #2
Default Re: Where to find pinion gears?
Which motor plate are you using? Many of the big block motor plates in the standard location will need a big pinion to reach the spur.
Sent from my LGMP450 using Tapatalk
spoo76 is offline   Reply With Quote
Old 01-02-2019, 04:40 PM   #3
A little pricey, but you're getting 4 brass pinions to play with.
https://rover.ebay.com/rover/0/0/0?m...2F362519810428
https://rover.ebay.com/rover/0/0/0?m...2F362519811614
Old 01-02-2019, 06:38 PM   #4
Thanks man yeah I havent messed with the plate that much yet. Was going to try and put it in the same location up along the case. Trying to keep it as tight as possible to fit inside my little scaler interior.
Old 01-02-2019, 06:41 PM   #5
Thanks for the links I may grab a set and try changing up the motor location.
Where to find pinion gears? - Similar Threads
Helical ring and pinion gears sets with an offset pinion? Calderwood General Crawlers 6 09-14-2013 09:06 PM
where to find metal ring and pinion gears(diffs) my96on22s General Crawlers 13 01-08-2009 12:27 PM
Questions about spur gears and pinion gears... Chadworkz General Crawlers 6 12-03-2008 02:04 PM
help me find an 11 tooth pinion vulturebikes Losi Mini-Rock Crawler 4 11-25-2008 11:04 AM
where to find a pinion? rockhound General Crawlers 5 06-25-2005 09:47 AM
