Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: got one too
Old 09-03-2008, 04:21 PM   #1
Default got one too
so far so good. charged the pack for maybe 15 mins, it ran about 30. recharging now. a little top heavy, but it sticks to everything it can climb in my living room. outdoor testing to come....
superelmer is offline   Reply With Quote
Old 09-03-2008, 04:31 PM   #2
it looks very capable how much room is there on the front axle for a batery or somthing?
Georgerm is offline   Reply With Quote
Old 09-03-2008, 04:34 PM   #3
with the stock body, not much. with a body that's a bit more scale (longer, all the way out to the front tires, like the front of a truck?), there'd be plenty.
Old 09-03-2008, 07:07 PM   #4
ok its very temting to get one
Old 09-03-2008, 09:26 PM   #5
I would think that the Max Amps 2S 860mAH Lipo would fit nicely on the servo...the front tri-link looks like a sweet spot also.
http://www.maxamps.com/proddetail.ph...74-Pack&cat=82
They also have an 1100 mAH...a bit larger, but more run time:
Or, just reduce the stock placement weight with the Dynamite 1900 mAH Lipo:
http://www.horizonhobby.com/Products...ProdID=DYN1421
Just watch your run times, or install an external voltage cut off.
CreepyCrawl is online now   Reply With Quote
Old 09-04-2008, 09:55 PM   #6
first pic with other 1.9's???? i've only got one other set..
Old 09-09-2008, 12:10 AM   #7
put the battery on the back servo plate, lowered the body, limited the travel a bit, skinny wheel spacers (just enuf to make the nut flush with the axle end)and added weight to the front tires...lots more stable, sidehills like a champ...
Old 09-12-2008, 01:11 PM   #8
since i have a couple old mini t batteries, i have an idea...chop one up, put 3 cells on the front and 3 cells on the back upper link (on a plate). or maybe 4/2? still needs more front weight, i think...i'm trying to keep my mods down until one of these companies comes up with some real parts. i don't wanna build this 4 times, or see someone elses's simple mod that i didn't think of .
ps, don't say switch to lipos, i ain't switching just yet.
Old 09-12-2008, 01:37 PM   #9
I did the 3 in front and 3 on back, it works great
nmanuel01 is offline   Reply With Quote
Old 10-27-2008, 07:53 PM   #10
just tinkering...old body, maybe clean it up, bob the bed, ditch the rear radiator and make a yota/mrc? or frankenstein it into a mrc rear axle/ifs prerunner on 1.9s, like one of my other teflon (search for that, if you're curious) builds...
hmmmm....
Old 10-27-2008, 11:40 PM   #11
Talking
Looks good with that body !
DeeBo66 is offline   Reply With Quote
Old 10-28-2008, 01:10 AM   #12
i'm a die hard toyota fan, and i dig the new crewmax tundys. anyone seen one of these yet? 1:14 might be kinda close to the mrc's size? i can't find specs on it...
Old 10-28-2008, 01:06 PM   #13
l trail chassis ordered....maybe i'll track down an fj cruiser body. (C'MON PROLINE!!! ANSWER MY PRAYERS!!!!)
next up is drive shafts and rock crushers, i think...
Old 10-28-2008, 05:55 PM   #14
crewmax body is a no go. checked out TRU, they're vey small...wheelbase is about 9 inches, wheel openings are maybe an inch. :( sniff
Old 11-04-2008, 12:57 PM   #15
needs more wheelbase, and the crushers look kinda big. still working with it....
Old 11-04-2008, 06:12 PM   #16
more progress today. front and rear 4 links (more clearance under the L Trail), frame mounted steering, and cut up the body a bit....it's getting there...
Old 11-04-2008, 10:09 PM   #17
Planning my Comeback!
jpterbl1's Avatar
nice job, cant wait to see it when your done
jpterbl1 is offline   Reply With Quote
Old 11-09-2008, 12:24 AM   #18
i need driveshafts! pics make it look a little taller and skinnier than it is in person, kinda looks like a mud truck with stock width yota axles on 44's....yet i like it. l trail is causing me a headache. it's too flexy for the frame mounted steering. when the servo pushes, the frame shifts more than the tires. looks like i gotta make some sort of bracing for it. the gaping hole in the bed will be covered soon, sorta making a black lexan tonneau cover for the back. prolly gonna make a similar piece to cover the back window area.
Old 11-09-2008, 03:14 AM   #19
Great job on the build . Keeping an eye on your progress.
Sprint 80 is offline   Reply With Quote
Old 11-25-2008, 12:32 PM   #20
...but, but, i'm a toyota guy....
