| | #1 |
| MadDogRC LLC ![]() Join Date: Mar 2007 Location: Petaluma
| First off, love this little truck!!! Pulled it out of the box just a couple hours ago. ![]() Nicely designed rig that has the feel and look if its bigger competitors. I drove it out of the box for 5 min and it tended to roll over backwards but hooks up everywhere! While waiting for the battery to charge I removed the servo saver and added about 3/8 of an ounce of lead to the front wheels. Feels more balanced now and will work killer. ![]() Also happened to have a LiPo that is the perfect fit: ![]() Cant wait to start driving and modding this sweet little rig, Thanks Losi!!! |
| Sponsored Links | |
| | #2 |
| Rock Stacker Join Date: Mar 2007 Location: WV
| Does the ESC have LiPo cutoff? |
| | #3 |
| Newbie Join Date: May 2008 Location: Jersey Shore BAR's (BIG ASS ROCKS)
| no one seems to have any tech specs on the "mystery esc", search'd, ask'd....no info....may have to go with the sidewinder micro http://www.maxamps.com/proddetail.ph...4-Pack&cat=182 |
| | #4 |
| Losi Rep ![]() Join Date: May 2005 Location: Ontario
| No Lipo cutoff |
| | #5 |
| Ya I was thinking of a stand alone LiPo cutoff unit or a Mamba 25 but want to keep it stock for now as there is talk in our area of having a stock class comp. Hey Rich I though I saw some literature in the Mini Crawler box that says Losi has a LiPo for this rig (even saw a p/n)? |
| | #6 | |
| I wanna be Dave Join Date: Oct 2006 Location: Laying low...
http://www.horizonhobby.com/Products...rodID=LOSB9863 But here's the Losi Lipo that should fit: http://www.horizonhobby.com/Products...rodID=LOSB9830 Or for a bit higher mAh: http://www.horizonhobby.com/Products...rodID=LOSB9830 Better yet, for mounting on the front Tri Link, grab a couple of these sweet little packs from Max Amps: http://www.maxamps.com/proddetail.ph...74-Pack&cat=82 | |
| | #7 | |
http://www.horizonhobby.com/Products...rodID=LOSB9833 The LOS9830 like you mentioned is referenced on the "Warning" sheet included with the owners manual. Eitherway a LiPo may be in the future for this rig. Also a note on the steering servo, after some backyard crawling the servo w/o saver is starting to scream at me a bit. Not sure what to do I'm thinking of putting the saver back on. Oh and I actually ended up with 3/4oz per front wheel (not 3/8 like I stated above) | |
| | #8 |
| I've throughly beat this rig the last couple weeks and have only had one casuality, the dreaded servo. And since a stock class hasn't materilized in my area and I also couldn't hold out any longer, I had to start turning screws. My stage one mods include: -Removing the electronics tray and replaced with 60mm axial links. -Relocated upper shock mounts to the electronics tray holes using axial 3mm spacers. -Sidewinder micro ESC -3s 430mAh Li-Po from Max Amps (was a 860mAh AX10 split pack that I disassembled into two packs) -I mounted the Rx on the trans and the batt and ESC on TLT servo plates zip-tied to the upper three link. ![]() Little Li-Po fits perfect inbetween the shocks: ![]() Sits lower for better CofG but hurts break-over angle abit: ![]() I also added more weight to the wheels so now I have 1oz in ech front and 3/4oz in each rear. I also got a new body coming in the mail that I'll mount that up in a couple days. |
| | #9 |
| Suspension felt a bit soft in this configuration so a few tweeks were in order: -TCS soft internal springs with 34wt up front, 45wt in the rear -Mini Grappler body -TCS upper link and rear plates -TCS button head hardware -11t pinion ![]() The internal springs helped lower the stance a bit more ![]() flex: ![]() torque twist is gone and suspension seems to works well, I will give it a run tomarrow |
| | #10 |
| Axial Team Driver ![]() Join Date: Feb 2005 Location: OC
| Looks awesome! Hope my TLT 1.9 doesnt hurt its feelings too bad. FYI: the 11.1V isn't allowed per the rules :-( Wish it was because I have the same exact split pack I wanted to turn into two packs for this class. |
| | #11 | |
Those 3s 430Mah packs only lasted 10-15min anyway I'm in the middle of making a axle mount servo/batt plate for the the 2s 1200Mah pack shown earlier in the thread. | |
| | #12 | |
I need to find a pack around that size, I have a 2100mah but its too big for these builds. | |
| | #13 | |
https://rcpcrawlers.com/product.php?...&cat=40&page=1 seems around the same size as the 1250 venom and thunder power | |
| | #14 | |
| | #15 |
| Been doing a ton of work on this little rig, funny casue I thought a smaller rig would mean less work... Anyway, got a HH Mini-TorqueMaster, nice little motor, I like the integrated PCB with caps, smooth startup and has plenty of torque and wheelspeed ![]() (like a pic helps...) Did the rckjeep beadlock mod with 2"ABS. I cut the width at 3/4" but wish I would have used SCH 80 instead of the thick ass SCH 40 ![]() (1/8" air-hole not pictured also added some lead rope under the ring) Look good with the new Blue compound Bashers, not sure how they will perform... ![]() rear 4-linked with custom Al. plate, also added some new shocks ![]() front 4-link with fatrock style battery/servo mount ![]() I tried to get the new metal gear Hi-tec servo mounted as low as possible so I used a piece of 1/4" Acetal and counter sunk some screws to attach it to the plate |
| | #16 |
| Planning my Comeback! ![]() Join Date: Oct 2004 Location: Somewhere in the middle
| Great looking rig keep it up |
| | #17 |
| Rock Crawler Join Date: Sep 2008 Location: PA
| What's the reason for mounting the servo that way? Just to get the battery on the axle? And why is it called fatrock mounting? |
| | #18 |
| Keep it real ![]() Join Date: Jun 2006 Location: Yakima,WA
| | #19 | |
| RCC Addict Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
| | #20 |
| Who's your Daddy-0! ![]() Join Date: Mar 2008 Location: Augusta
| Looking good! The $ is adding up on the mini huh |
| Thread Tools | |
| Display Modes | |
