| | #1 |
| Quarry Creeper Join Date: Mar 2007 Location: northern utah
| ok guys i just picked up one of these little guys and it is a blast! what all are you guys doing to get some better performance out them? it seems like its almost too light, at least on the axles so i planned on adding weight to the wheels and moving the battery on top of the servo. also i think it sits a little too high so i might tear the shocks apart and put some limiters in there. post up your tips and tricks or thoughts |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Sep 2008 Location: Encinitas
| The spacers at the top of the springs just pull right out. You don't need to disassemble anything. It lowered the ride height a bit. |
| | #3 |
| i was meaning to KEEP it lower, those pacers will still let the suspension extend all the way out, where limiters will hold the truck lower to the ground so its more stable |
| | #4 |
| Pebble Pounder Join Date: May 2004
| With the spacers removed, I got more torque twist. I'm going to relocate the electronics, and try and reposition the shocks to get a lower ride heigth w/ the spacers installed. Probably change oil too. If that doesn't work, I'll 4 link the rear to eliminate the twist. Drives me nuts! |
| | #5 |
| Rock Crawler Join Date: Jun 2004 Location: back in Portland, OR
| all you need to do is move the shocks' upper mounting points from the shock mount to the corners of the chassis where the upper plate attaches. this will lower it a bit. Even further you can move the shocks' lower mounting points to the lower link mounts which is lower on the axle. You will have a lower ride, lower extension (relative to the chassis), but you will retain the articulation, so if you want to limit that you'll still need something. but if you do it this way you can use compression limiters rather than extension which are alot easier to install and remove and what not. |
| | #6 |
| | #7 |
| Basically you can use anything that fits around the shock shaft, inside or outside the shock. Generally people use fuel tubing because it is cheap, easy to cut to size quickly, and it can squash a bit so that it works kind of like a bump stop in the 1:1 world. Inside the shock (below the piston) the limiter will keep the shock from extending all the way out of the shock body which shortens the over all length of the shock and lessens the travel of the shock. This lowers the rig and limits articulation/suspension travel. Outside the shock (sitting on top of the spring retainer cup), the limiter only limits how far the shock can compress but does not change the length of the shock, so it only limits articulation/suspension travel. I hope this helps you out. |
| | #8 | |
Again, thanks to everyone for being helpful. | |
| | #9 |
| Rock Stacker Join Date: Sep 2005 Location: Fairmont (but always from Flagstaff AZ)
| i removed the battery tray, put the battery on the rear axel with a velcro strap held by the rear plate. put the electronics on the chassis with servo tape. and 12 oz of weight with the sticky wheels weights. 1 1/2 per back wheels almost double that to the front and some more on the axel and servo. that helped out a lot. i agree with some fuel tube to limit the travel about a 1/8". also lowered the body down about a 1/2 inch. it works a lot better. |
| | #10 | ||
this is what a compression limiter looks like. Note it is on the outside of the body and limits how much the shaft can compress into the body: ![]() This is an extension limiter. Note it will be on the inside of the body, below the piston, once the shaft is pushed through. It will limit how much the shaft can extend outside of the body: ![]() hope this clears things up and should also help you understand how both limit articulation but the extension spacer will also lower the ride because the shock will not be able to extend to full length. | ||
| | #11 |
| Pebble Pounder Join Date: Jan 2008 Location: Mission B.C. Canada
| | #12 |
| Quarry Creeper Join Date: Sep 2008 Location: Kennesaw
| Stupid question, but whats a 4-link for those of us who dont know? Any pictures of said 4-link? |
| | #13 |
| Quarry Creeper Join Date: Feb 2008 Location: Weddington
| Did you triangulate the lowers after you did the 4 link ? If not how is the torque steer ? |
| | #14 |
| A 4 link is a replacement for the stock 3 link the losi comes with, stock has a upper link mount mount on either side of the chassis and one at the axle (thus 3 link mounting points) a 4 link has two on the chassis and two on the axle, 4 link has a seperate link for each side and each end of the links has its own pivot point on each end, instead of the stock one piece y shaped link. I'll post more detailed pics once I get it all back together. |
| | #15 | |
| | #16 |
| | #17 |
| Ah, well that makes sense. Thanks for the clarification. |
| | #18 |
| no problem. just a friendly correction. I think you are the first one to try the four link. how is it fairing for you? not including all the other mods you did, how much difference in driving does the 4 link make? |
| | #19 |
| Haven't been able to try it on the rocks yet but so far testing in the house seems better, chassis doesn't flip to the left anymore under hard throttle and front right tire only lifts on extreme verticals (still gotta add lead to wheels). Changed the design for the upper links a bit, used Axial 45mm posts instead of stainless steel (will de-anodize) Traxxas long rod ends on the frame side and Ax10 rear lockout balls & cups on the axle end. |
| | #20 |
| Thread Tools | |
| Display Modes | |
