Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: Carvers Mini
Old 09-05-2008, 11:11 PM   #1
Default Carvers Mini
So far I've moved the Esc to the rear servo plate, I've moved the Rx onto the upper link on a piece of lexan zipped tied. I ditched the electronics/batt mount and I'm running an elite 1500mah 3cell pack behind the servo on a piece of lexan. I also installed some 35wt. oil and 2.5oz of weight to the front wheels. Future mods include: Losi grappler, and some experamenting with some memory foam. Here's some pics,
carver is offline   Reply With Quote
Old 09-05-2008, 11:14 PM   #2
I did all the Same Mods. Wheres the Pics?
Bigbadwhitey is offline   Reply With Quote
Old 09-05-2008, 11:15 PM   #3
Sounds interesting...but no pics!
wrightcs77 is offline   Reply With Quote
Old 09-06-2008, 02:33 AM   #4
3 cell is not going to work, 3.6v they still don't have enough power with 7.2v. i would rather have high center of gravity then no power.
Flyin Hawaiian is offline   Reply With Quote
Old 09-06-2008, 08:06 AM   #5
How much of a difference did those mods make for you? Was it a pretty substantial improvement?
kulangflow is offline   Reply With Quote
Old 09-06-2008, 11:00 AM   #6
It actually did make a good improvment, It will climb steeper hills and dosn't roll on it's lid as much.
Old 09-06-2008, 01:07 PM   #7
is that a stock chassis there on it
1beatjeep is offline   Reply With Quote
Old 09-06-2008, 03:53 PM   #8
yup it is, it has Axial posts for standoffs
Old 09-06-2008, 03:59 PM   #9
thanks
Old 09-07-2008, 12:33 AM   #10
Nice...looks killer with the body slammed.
I'll be doing the same mods, and running Max Amps 860mAH 2 cell Lipos on the front tri-link. Trying 50w oil all around though.
Thanks for the pics!
CreepyCrawl is offline   Reply With Quote
Old 09-08-2008, 07:04 PM   #11
I've added two more cells to that pack now. Gets plenty of run time and got the stock power back. yupee
Old 09-11-2008, 08:18 PM   #12
I installed some 45wt shock oil to the rears and made a huge diference. tourque twist is minimal. I also limited the shocktravle inside about 3/16" seems to be just bout right. Can't wait for the mini grappler
Old 11-15-2008, 05:39 PM   #13
Default UpDatE!
Finally got back to workin on the mini. Some more mods and a little tweakin made it an outstanding performer. Here's what i have done so far:
Tekin B1r
Spectrum Mini rx
800 mah 2c lipo
HH Mini torque master
Eritex 1.9 Magnums
Losi Grappler and Claws w/memory foam
Hitec 645mg for steering
Still to come:
AL. Adjustible Shocks, Late model or will wait for the MRC shocks.
Stainless steel links
Losi lockers
here's some pics for now I will shoot some of body pics after it's all cleaned up.
These wheels are sweet. Check out the Delrin rings, Nice.
Old 11-15-2008, 06:46 PM   #14
impressive list of mods.
JOOTZ is offline   Reply With Quote
Old 11-15-2008, 09:39 PM   #15
Thanks, It should be a tough contender this coming series. We are starting a 1.9 class and looking forward to it.
Old 11-15-2008, 09:42 PM   #16
calcat430d's Avatar
looks good charlie.
calcat430d is offline   Reply With Quote
Old 11-15-2008, 10:37 PM   #17
Thanks Kevin. More to come soon. Stay tuned.
Old 11-16-2008, 02:49 AM   #18
look im not going to lie, those wheels are sexy! great looking rig!
GearLoDriveSlo is offline   Reply With Quote
Old 11-16-2008, 10:04 PM   #19
Thanks, I like them too. These were the easiest wheels to mount ever. Thanks Gerame for these sweet wheels, I'll probably try the comp heavies as well. They look sick in white.
Old 11-16-2008, 10:46 PM   #20
what kind of mods/parts were needed to put the Hitec 645 servos in.
