| | #1 |
| Who's your Daddy-0! ![]() Join Date: Mar 2008 Location: Augusta
| It's a big difference so far......I still need to play around with it but much better so far...... |
| Sponsored Links | |
| | #2 |
| Well then.... ![]() Join Date: Feb 2008 Location: NorCal
| Kenny I'm thinking about doing the same. Did you use any internal springs? Looks maybe a little fuel tubing on the shafts/bumpstops might help? Can you tell us more? -Mike |
| | #3 |
| I got a spring kit from Harbor Fright. Has a ton of springs in it for $10. They are inside. And yes I do need to add some tubing to them. The Losi shocks are kinda different from the norm. I'll shoot some picts of them apart tonight to show you whats going on....... |
| | #4 |
| Quarry Creeper ![]() Join Date: Dec 2007 Location: #
| what is the gc of it. it looks a ton better im really likein how it looks. |
| | #5 |
| It's a 1 1/2 as it sits......I get it to 1 3/4 tonight and it should be good.... |
| | #6 |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| What weight oil? Are you still running the factory valving? |
| | #7 |
| I put some 40 in them. And the rest is stock.....except the springs....the springs are just big enough to fit over the shafts. I took the stops out of them as well..... |
| | #8 |
| Rock Crawler Join Date: Apr 2008 Location: Fondy, WI
| any updates on how its running with your droop set-up? also, can you post a link for the internal springs that you got? thanks! |
| | #9 |
| Newbie Join Date: Sep 2008 Location: Sydney
| One question, sorry if this sounds stupid, but putting fuel tube on the bottom end ( or top depending on how ur runnig ur shocks ) wouldnt this limited the amount of travel upwards or is that would u are aiming at only drop not up travel? |
| | #10 |
| It would do both.....and it is running great like this! JIA just got 2 today and will run them the same. Tonight will be tearing apart to work on the tube build I'm doing on it. See my other post on it..... |
| | #11 | |
| 06 Super National Champ ![]() Join Date: Jun 2004 Location: Tennessee
Fuel tubing on the shock shaft inside the shock limits down-travel (droop). To lower the rigs we'll be running internal springs. We'll use a sleeve on the shock shaft (outside the shock body) to both limit compression and set ride height. In the way these rigs will be set up the tubing on the shock shaft will serve three purposes:
| | #12 |
| Yea.....What Jason just said! |
| | #13 |
| Rock Crawler ![]() Join Date: Jan 2007 Location: caldwell,idaho
| nice rig i thought it was a 1/10 scale for a minute |
| Thread Tools | |
| Display Modes | |
