Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: Ax10 inspired MRC
Old 09-07-2008, 09:28 PM   #1
Talking Ax10 inspired MRC(updated pics)
Well I wanted to incorporate what I have learned with my Ax10, into the MRC. Here is what I came up with.
First of all I got rid of the electronics tray, very common on the ax10
I then made trays for the lower links, and proceeded to mount my electronics
the cells are obviously to big to mount on the axles so I took apart a battery I had for my recoil and looked at all my optioins
before that I mounted my shocks and re-enforced the chassis with some extra axial links I had. Well here is what I came up with, with all the weight up front it crawls incredibly well, now onto some pics....
What do you guys think, so far crawling over all the clothes and building supplies(Bathroom remodel), it has handled extremely well.....
nmanuel01 is offline   Reply With Quote
Old 09-07-2008, 09:51 PM   #2
battery looks like it will rub if not limit or stop the front articulation.
Crawler Noob is offline   Reply With Quote
Old 09-07-2008, 10:13 PM   #3
I think im going to do my electronics like that but I use a lipo it fits much better.
Jason S is offline   Reply With Quote
Old 09-07-2008, 10:13 PM   #4
here is its crawling off the entertainment center, the batt just moves with the crawler. so far no issues with it rubbing or limiting articulation...
Old 09-07-2008, 10:14 PM   #5
a lipo would kick but, but I dont have a lvc for it yet.
Old 09-07-2008, 10:39 PM   #6
hey guys, for time poster and just getting into crawling and i think the MRC will be perfect to get me started, anyway can you tell me what size links those are from axial, i found them on tower but see they come in multiple dimensions...thanks
acsubie is offline   Reply With Quote
Old 09-08-2008, 11:57 AM   #7
Default saddle pack, better weight distribution
ok even though i did not notice any articulation problesm with the batt, i did feel it was really heavy up front, so i made a saddle pack and now it feels way better.....check it out
Old 09-08-2008, 11:59 AM   #8
Those are the 55mm links they are about 10mm short but brought the chassis together with screws no big problem.
Old 09-08-2008, 06:06 PM   #9
newbie8324's Avatar
thats a killer battery set up
newbie8324 is offline   Reply With Quote
Old 09-08-2008, 07:00 PM   #10
thanks i think it balances the truck out really well
Old 09-09-2008, 11:29 PM   #11
it wouldn't really be a crawler without at least a little of "that green" on it, would it?
dezu is offline   Reply With Quote
Old 09-10-2008, 01:05 AM   #12
Hello
I have (before I got the Mini crawler) a similar batterypack. I'va used the similar batterypack on my AX10 (only bigger cells) for months. A perfect pack - weight om both axels. For the minicrawler I've ordered the pack with the standard connector as on the minicrawler.
KuJo is offline   Reply With Quote
