| | #1 |
| Newbie Join Date: Sep 2008 Location: San Jose
| i was reading all kinds of different amounts people had, so i put 5 on each tire which totals it to 2.5 oz. in the front. Is that good? Last edited by driftin2crawlin; 09-08-2008 at 05:48 PM. |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Aug 2008 Location: orlando
| i got 1.5 oz in each tire- and 1oz to the bottom of the servo 3 oz total... and it has helped a ton |
| | #3 |
| Rock Stacker Join Date: Sep 2005 Location: Fairmont (but always from Flagstaff AZ)
| i had to cut the 1/4 oz weights in half to fit in the rim (tire side) so i have about 1 oz inside and 1 1/2 hub side per wheel. the i have 2 1/4 on the axel both on the servo and the top of the axel. for the rear i have the battery and only hub side weight so 1 1/2 oz per wheel. 4 full stick of sticky weights. it really helped. doesnt seem to hurt the servo yet, but i life to kill servos (i guess) |
| | #4 |
| i killed the stock servo and the 1st replacement hitech (mighty mini 255) on the 3rd one now... i run it until this gets warm and stop..... kind sux if the 3rd one dies i'll fab a new front plate and use a full size ... hitech 645 |
| | #5 |
| RCC Addict Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
| I've put some 1/4 oz self stick wheel weights from Car Quest on mine. I put 6 pieces (1.5oz if my math is correct) on each front wheel and none in the back as of yet. The rear axle currently has the battery mounted on it until the next payday when I can get a little park flier li-po and charger for the truck. I may double the weight up front and the 1.5oz per rear at that point. |
| | #6 |
| Thread Tools | |
| Display Modes | |
