Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: Ditch your upper plate (Battery/Electronics Plate)
Old 09-08-2008, 12:25 AM   #1
Default Ditch your upper plate (Battery/Electronics Plate)
It looks like everyone is doing this to make their rig less top heavy.
When you remove the upper plate you need to make sure to replace the reinforcement that you took away. After relocating the ball joints I cut a piece of aluminum rod and put a steel thread through it. I utilized the same holes as the ones for the body mount so I was sure to use the same thread that the body mount screws into. (See attached pic)
Relocate the ESC to the back axle. I used a zip tie to guide all the wires forward then some double stick mounting tape to secure it down.
The receiver was mounted to a thin piece of PVC that I cut out and hot glued into place.
The LiPo battery fits with no trouble on the front link. No clearance issues.
FDAapproved is offline   Reply With Quote
Old 09-08-2008, 06:45 AM   #2
thanks for the close up pics...looks great. wait'n for my ups guy....
can u show a more "zoomed out" view of all yur mods
thanks
njrockcrawler is offline   Reply With Quote
Old 09-08-2008, 07:32 AM   #3
I understand removing the electronics to lower the CG, but Why remove the top plate?
Clearence issuses or what?
macruz is offline   Reply With Quote
Old 09-08-2008, 08:00 AM   #4
Two reasons, one is to move the shockmounts toward center a little. This lowers the ride height, improving the CG. Two, is to remove the dead weight of the plate itself, also helping the overall CG. With the esc/rx and batt. relocated, why keep it? IMO, it looks much cleaner
RockAddict75 is offline   Reply With Quote
Old 09-08-2008, 08:27 AM   #5
I'm not knocking you. BTW
I'm a know nothing squirl just trying to get a nut of knowlege.
Is the plate metal or plastic?
Old 09-08-2008, 08:39 AM   #6
Plastic
The whole assembly(plate, battery hold down posts & strap, and steel spacers) weighs in at 31 grams! Thats a lot of weight up high on such a little rig. Try it, you WILL notice a significant improvement
Old 09-08-2008, 09:40 AM   #7
thanks
Sure, here are some more pics.
Old 09-08-2008, 09:53 AM   #8
Default clean set up
i have my pattery on the rear axel and the elctronics are inside the chassis (motor side) mounted verticle on the chassis. i cut a pic pen and put it inbetween the body post (so the bolt will keep it in place) and used a zip tie to squeeze it in place. but only in the front.
the other 2.2 guy is offline   Reply With Quote
Old 09-08-2008, 05:53 PM   #9
newbie8324's Avatar
i was waiting for someone to mount the battery to the rear axle
newbie8324 is offline   Reply With Quote
Old 09-09-2008, 08:11 AM   #10
Nice and clean. I can't wait to see the difference when I do this as well. Thanks!
cheesefart is offline   Reply With Quote
Old 09-09-2008, 11:20 AM   #11
jimbiss's Avatar
What battery do you have that fits behind the servo?
jimbiss is offline   Reply With Quote
Old 09-09-2008, 11:29 AM   #12
Its a 2 cell LiPo battery. They are flat batteries that are very low profile. I haven't actually hooked this battery up to the car because I don't have a charger for it yet. At this point I'm still running the stock battery zip-tied to the top, haha.
Old 09-09-2008, 11:38 AM   #13
jimbiss's Avatar
I guess I should have been more specific. What brand & size (mah) of lipo fits?
Old 09-09-2008, 11:41 AM   #14
Not sure yet. The batteries were made by my neighbor. He buys a ton of cells then makes his own packs. I'll tear it open later and let you know what I find.
