Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: Your thought on this pack and charger
Old 09-08-2008, 06:28 PM   #1
Default Your thought on this pack and charger
7.4V 800mAh LiPo Battery by ParkZone
PKZ1032
Specs
  • Type: Li-Po
  • Capacity: 800mAh
  • Voltage: 7.4V
  • Connector Type: BEC
  • Number of Cells: 2 cell
  • Weight: 1.5 oz (42 g)
  • Dimensions (WxLxH):1.16" x 2.02" x .60" (29.5mm x 51.4mm x 15.3mm)
  • Maximum Continuous Discharge : 10C
  • Charge Protection Circuitry: Balance Charge Lead used on PKZ1040 charger
and
2S DC LiPo Balancing Charger by ParkZone
PKZ1041
Now I do have a stupid question too, the balance leads are inserted into the balance plug differently that that of the Blade CX/2 packs and charger, but the plugs appear to be the same. Can I safely swap the wires so it can be charged with Blade CX/CP 2-3 cell charger?
Thanks
BJoe is online now   Reply With Quote
Old 09-09-2008, 03:36 PM   #2
Thats the batt Im gonna use. Its the batt from my blade ez that I never fly anymore. As far as charging I'll use parkzone charger it came with. All I'll do is put losi plug on it. This batty is so small ya can hide it anywhere on truck and leave wt for the wheels for cg.
turner3123 is offline   Reply With Quote
Old 09-10-2008, 02:11 AM   #3
Looks like the PKZ1032 should work with the BCX/P chargers! Now I just have to wait for payday..............
Old 09-10-2008, 09:48 AM   #4
jimbiss's Avatar
What kinds of balancing tap do those have?
Nevermind, I found it. They are the same as align, xh, e-flight
jimbiss is offline   Reply With Quote
