Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: hardware sizes
Old 09-09-2008, 11:26 AM   #1
jimbiss's Avatar
Default hardware sizes
So does losi use metrics or standard screws on these? What size?
jimbiss is offline   Reply With Quote
Old 09-09-2008, 12:48 PM   #2
Jim
The screws on the Losi MRC are metric. Most of them are 2mm, but there are some 3mm screws and the wheel nuts are 4mm. Also, the links have 3mm threads.
Buckwheat is offline   Reply With Quote
Old 09-09-2008, 12:50 PM   #3
jimbiss's Avatar
Thanks
Old 09-09-2008, 10:25 PM   #4
Losi Rep
Rich Trujillo's Avatar
I don't recall the 3mm screws but I also just finished a 12 hour drive from Utah . Most are 2mm or 1.5mm. All are metric
Rich Trujillo is offline   Reply With Quote
Old 09-09-2008, 10:37 PM   #5
what about the included allen wrench? What is that for? was I just given a bad one? Because I can't find any screws that it fits on this truck. It is slightly smaller than the screws that it looks like it should fit and starts to strip out the heads because it can't grip. I have tried it on many different screws on the mrc and it just wont unscrew any of them. what's the deal on this? It is kind of frustrating because I'm trying to take it apart but I can't.
RCMFMaxxMan is offline   Reply With Quote
Old 09-09-2008, 11:07 PM   #6
Does this mean you got scewed
MOfroggy is offline   Reply With Quote
Old 09-09-2008, 11:21 PM   #7
it's for the slipper clutch, I think
dezu is offline   Reply With Quote
Old 09-09-2008, 11:31 PM   #8
no thats a lock nut. I'm talking about the allen wrench, or hex wrench if you prefer. For the itty bitty countersunk screws... or atleast it looks like it should be for those. And I tried my own metric wrench that is closest and had the same results... maybe the screws suck? I wish i could atleast get the things to unscrew so I could replace them with some higher quality screws.
Old 09-10-2008, 01:07 AM   #9
Losi Rep
The wrench should be a 1.5mm. I'll double check what wrench has been included to make sure it is correct. All of the flat heads require a 1.5mm allen wrench and the cap head screws are 2mm.
Old 09-10-2008, 04:44 PM   #10
Yeah I'm pretty sure it was right because I tried my own set of metric wrenches with the same results. I think the smaller screws are just a little more touchy. I'll figure a way to massage them out of the there and will probably just replace them with some harder screws. thanks rich.
Old 09-10-2008, 04:47 PM   #11
666
666's Avatar
Losi metric eh? Thats odd, I have always had my tool kit for everything else and my standard Losi tool kit.
666 is online now   Reply With Quote
Old 09-10-2008, 05:45 PM   #12
that was what I was thinking but they look metric... i think. I know associated is all standard and I used to own a xxx-t mfe a few years back but can't recall what hardware that used. I want to say standard but its been awhile.
Old 09-10-2008, 06:46 PM   #13
Perpetual Newbie
Cave Dave's Avatar
The hex sockets in the screws are definatly on the big end of the tolerance.It also seems the socket is not as deep as most ISO standard screws are.RCMFMaxxMan if you have a grinder, lightly grind the end of the hex key and leave the bur on it.This allowed me to get the screws out without stripping the hex.Hope this helps.
Cave Dave is offline   Reply With Quote
Old 09-11-2008, 12:35 PM   #14
thanks i'll give that a try
Old 09-11-2008, 01:16 PM   #15
i've had just about every screw out of mine and didn't have problems with any of them. i've got xtm hex drivers. maybe my cheap hex drivers are out of whack just right.
HotCarl73 is offline   Reply With Quote
Old 09-11-2008, 06:55 PM   #16
Rich,
There are 3mm set screws in the metal universals on the driveshafts. And the links use a 3mm thread. And 3mm threads on the ball ends for the top shock mount. The threads are indeed metric.
