Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: servo battery plate
Old 09-11-2008, 09:50 PM   #1
skid's Avatar
Default servo battery plate
Couldn't wait, just don't have a battery to put on it yet.
skid is offline   Reply With Quote
Old 09-11-2008, 11:37 PM   #2
Does the passenger shock hit the back of the servo? I ask because the plate looks like it would have to be clearanced right into the bottom of the servo.
Looks awesome though!
TooSlow is offline   Reply With Quote
Old 09-12-2008, 06:59 AM   #3
Default plate and battery
I've made a similar plate for mine. I have yet to build the battery. I plan on taking a 6 cell 2/3a and doing 4 calls over 2. I did they same thing to get sub C's on the axel plate I made for my ax10 and it works out fairly well.
Only concern I have with my MRC version is strapping the battery down without getting into the path of the shocks or servo. Going to try super duty velcro first so try to avoid being locked into only one battery (servo taped in).
hcssbd is offline   Reply With Quote
Old 09-12-2008, 08:58 AM   #4
skid's Avatar
Shock comes within a 1/8".
Old 09-12-2008, 09:58 AM   #5
Did you mount to the servo plate or did you remove the stock servo plate?
macruz is offline   Reply With Quote
Old 09-12-2008, 11:10 AM   #6
skid's Avatar
I removed the stock servo plate.
Old 09-13-2008, 03:38 PM   #7
I got my battery done today, and it works well.
I still use the top tray, swapped ESC and RCVR locations though to make the wire lengths work better. Besides, heat rises
If Ike hadnt helped flood out my spill ways I play in I could truly test it, but inside it does well.
