Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: Shoei1 MRC
Old 09-12-2008, 02:52 PM   #1
OFFROADJERKY.COM
Shoei1's Avatar
Default Shoei1 MRC
Well I picked one up last night. First I put some wieghts in the wheels and I was lucky enough that losi didnt glue the tires on well. The next mod that I wanted to do is Make a servo/Lipo mount. Well I did the CAD this morning and sent it to the laser cutter.
The Solidworks rendering
The laser cutter
With the servo and lipo mounted. Its a tight fit.
I plan on picking up a Hitec HS-225mg does anyone know how that compares to the stock servo.
Shoei1 is offline   Reply With Quote
Old 09-12-2008, 07:09 PM   #2
Mic
Looks good. It there enough clearance at full lock steering?
I used a full size servo in mine it really is not that much bigger than the stock one. But it looks like a tight fit for you already so it may put you over the top.
Mic is offline   Reply With Quote
Old 09-12-2008, 07:44 PM   #3
OFFROADJERKY.COM
Shoei1's Avatar
yes it rubs the servo a little but not enough to worry about. Well I picked up a HS-5245mg and i will let you all know how it works.
Old 09-13-2008, 06:02 PM   #4
where are the servo mount screws on the left??? (passenger side)
not bad though.....
roksloski is offline   Reply With Quote
Old 09-13-2008, 06:34 PM   #5
OFFROADJERKY.COM
Shoei1's Avatar
Well in the end the servo mounts will be cut off to clear the tire. So the servo will be mounted on one side and also have servo tape holding it down.
So i have a question for the MRC owners. i was driving and last night and the ESC just stopped. i took it home check the out put with a meter and it had only like 2volts comming out. Is the ESC done? Some help would be nice
Old 09-13-2008, 07:12 PM   #6
With The Slock Battery When It Dies The Steering Will Work But The Motter Will Not So I Would Check The Battery.
Jason S is offline   Reply With Quote
Old 09-13-2008, 09:20 PM   #7
OFFROADJERKY.COM
Shoei1's Avatar
well i left some stuff out. I changed the servo to a HS-5245mg. I charged the battery and it drove for like 5 mins or less and again it stopped. Could i need a BEC?
Old 09-13-2008, 11:34 PM   #8
i would def use a BEC to be safe.
jedsled is offline   Reply With Quote
Old 09-14-2008, 12:33 AM   #9
yeah go with a bec that way you can run the servo off it's own battery and not cause issues with the esc.
a1racer is offline   Reply With Quote
Old 09-14-2008, 02:41 AM   #10
OFFROADJERKY.COM
Shoei1's Avatar
Well i put the stock servo on and still nothing works. I think the radio isnt bound any more. I tried binding it and it wont bind.
Old 09-28-2008, 01:07 AM   #11
OFFROADJERKY.COM
Shoei1's Avatar
Well a lil update
CC micro siderwinder esc
New updated servo mount
Moved reciever to the front
Old 10-10-2008, 06:31 PM   #12
looks good
iwantoffroad is offline   Reply With Quote
