| | #1 |
| Moderator ![]() Join Date: Apr 2004 Location: In my head
| Got mine in today charged up the battery and took it for a test run in stock condition before the mods start. I was very impress with the truck even with the big heavy battery up top. This little crawler will be a great starter truck for many people. Here are a few pics I'll say again how impressed I was with it's crawling/ climbing ability out of the box!!! The ESC is great with the drag brakes; Losi really got that one right. The tires could be better and I'm sure all the ones about to be produced will be great. |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: May 2008 Location: Jersey Shore BAR's (BIG ASS ROCKS)
| awesomerific....1st pic looks like a lil' puppy dawg giv'n us the paw. |
| | #3 |
| For those that want to keep the upper battery tray but want a light weight lipo the MaxAmps 1100 2 cell fits great. It weights almost half what the stock pack weighs. 2¼ oz verses 4¼ oz for the stock pack. |
| | #4 |
| Quarry Creeper Join Date: Jul 2008 Location: Lawton
| Which conector do I pick for this battery on the max amps website? and what whould be a good affordable charger? |
| | #5 |
| I'm pretty sure it's the "micro 1/18th scale plug". But you might want to call them to be 100% sure. I use Deans plugs on all my other stuff so I put a deans plug on the ESC. If you already have a good NIMH/NICD charger then this would be a good lipo/123a charger that has a built in balancer. http://www.maxamps.com/EOS0403i.htm If you don't already have a good NIMH/NICD charger then this one does those along with lipos. http://www.maxamps.com/EOS0606i.htm Keep in mind both or those are DC only chargers, meaning you can't plug them in the wall. (You can use a old car battery or a power supply to charge at home). Or this one is AC/DC and charger NIMH/NICD and lipos. http://www.maxamps.com/EOS0606i-AC-DC.htm I have a Duratrax ICE charger which is also a good charger. Just remember you have a have a balancer with lipos, and each brand of lipos have their own type of balancing plug. The charger from MaxAmps are Hyperion so they use that style of balancing tab. If you do have a different lipo Maxamps sells adapters so you can balance those. If you get a charger that doesn't have a built in balancer then you'll have to buy on of those too. |
| | #6 |
| Did the basic mods, remove the battery tray, flipped the trans around, put the ESC on the rear axle, reciever on the rear upper links, and battery on the front upper links. The MaxAmps 1100 2-cell lipo fits really well and still has a low profile. I may end up using a 860mAh becuase it would be smaller. I added a Novak lipo cut-off to protect teh lipo from low voltage. Added 1.5oz of weight to each front wheel. I move the shocks to where the battery tray used to mount. And to add support back to the frame I used some old AX-10 standoffs. I drilled the chassis where the body mounts were and drilled the standoff so I could run a peice of 4/40 all thread through both. The standoff was a little short so I put a nut on each side then tapped the body mounts and srewed them onto the all thread in the stock location. Also lowered the body. Seeme to climb alot better. Now the tires seem to be the biggest weakness. Still need to mess with the shock oil and limit the flex. But lowering the CG helped alot and the rig is very capable. Here are the pics and a before and after pic of the same off-camber line thst it keep flipping on before the mods now it does it with ease. Oh yeah the wiring is a mess....I'm not known for pretty wiring. Nothing is pinched or in a bind so it's all good just not pretty. I might try to clean it up later..... |
| | #7 | |
| I wanna be Dave Join Date: Oct 2006 Location: Laying low...
http://www.maxamps.com/proddetail.ph...74-Pack&cat=82 | |
| | #8 |
| RCC Addict ![]() Join Date: Nov 2006 Location: southaven
| | #9 | |
| RCC Addict Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
![]() ![]() ![]() But instead of soldering up Deans plugs to the truck and Li-Po just yet, I made an adapter from the original battery (now has a Deans female pige tail for my Mini-T on it) and a MPI female BEC plug set | |
| | #10 |
| Newbie Join Date: May 2006 Location: Akron
| ? was wondering what kinda runtime you were getting with lipo and stock batt Last edited by RCohio; 09-20-2008 at 09:18 AM. |
| | #11 |
| Can't really remember just used the stock pack once. Maybe 45min-1 an hour. On the lipo I haven't drove it until it went dead, well over an hour. |
| | #12 |
| Rock Crawler Join Date: Mar 2006 Location: "Crawlerbama"
| Do they come stock with the aluminum U-joints? JP |
| | #13 | |
Yup, 100% OEM | |
| | #14 |
| Thanks for the info guys . rear locker plate are they makeing metal ones for these and is this a weak point of the rig |
| | #15 |
| | #16 |
| Thanks sweet rig JP |
| Thread Tools | |
| Display Modes | |
