Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: Mini LST Shocks work great
Old 09-14-2008, 12:36 AM   #1
Back in the WATER!
dpdsurf's Avatar
Default Mini LST Shocks work great
I had some mini LST shocks from 3 racing laying around so I threw then on the Losi MRC. Nice improvement! Reduced the articulation slightly which I wanted and 100 wt oil and the preload screwed down on the driver rear almost completely got rid of the drastic torque twist. I definately recommend these to those looking for a shock upgrade.
dpdsurf is offline   Reply With Quote
Old 09-14-2008, 01:24 AM   #2
nice. how is the mounting situation? what screw size? i would think it would be a larger screw size and if it is did you just go ahead and drill out the mounts i take it? by the way, those things look so beefy on the tiny truck!
RCMFMaxxMan is offline   Reply With Quote
Old 09-14-2008, 01:37 AM   #3
I just swapped in a set I had lying around also, but the stock springs are a little too stiff, and it limits the articulation quite a bit.
jdmstuff is offline   Reply With Quote
Old 09-14-2008, 02:10 AM   #4
Back in the WATER!
dpdsurf's Avatar
I used some M3x16 button head screws in place of the stock ball screws up top. The stock lower screws still work.
Are you using the 3 racing shocks? The stock springs are soft on mine.
I'm happy where the articulation ended up. It has too much in stock form.
Old 09-14-2008, 03:10 PM   #5
cool deal. agreed about the stock articulation, but now it looks perfect!
Old 09-14-2008, 03:11 PM   #6
666
666's Avatar
Very nice!!
666 is offline   Reply With Quote
Old 09-14-2008, 03:35 PM   #7
awesome, ive got 2 sets of those laying around here.. now i just need a losi mini crawler.
dieselfuel is offline   Reply With Quote
Old 09-15-2008, 04:04 AM   #8
Well then....
mann0mann's Avatar
So the hole in the bottom of the shock is made to accommodate a 3mm screw. The screws for the bottom stock shocks are 1.5mm correct? So are you just using the stock screw and allowing for "play" in the mount?
I don't think it would be a big deal...just making sure that I understand how you mounted them at the axle
mann0mann is offline   Reply With Quote
Old 09-15-2008, 12:58 PM   #9
Back in the WATER!
dpdsurf's Avatar
The mini LST shocks have a smaller eye in the ball of the rod end that takes the smaller screw, not a typ 3mm. So there is little to no play at all. These shocks fit like they were made for it.
Old 09-15-2008, 01:11 PM   #10
Who's your Daddy-0!
TattooKenny's Avatar
So your saying the TLT shocks are 1.5mm holes? I think he is asking was there any modding or drilling going on to mount them in any way?
TattooKenny is offline   Reply With Quote
Old 09-15-2008, 01:24 PM   #11
Back in the WATER!
dpdsurf's Avatar
I don't think that is what he was asking and we are not talking about the TLT in any way here, but the answer is no. There is no modding required in any way. Yes, I believe they are 1.5mm. They bolt up like they were made for it.
Old 09-15-2008, 01:55 PM   #12
Who's your Daddy-0!
Sorry I meant "LST" not "TLT"......
Old 09-15-2008, 02:14 PM   #13
Throwing Grenades
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
A link for anyone wanting a better pic of the shocks:
http://www.3racing.hk/products.php?products_key=917
Nice find by the way. I like that they have a ball end at the top. I might be picking a set up.
Harley is online now   Reply With Quote
Old 09-15-2008, 02:18 PM   #14
'08 2.2 National Champ
Just Zach's Avatar
I just picked up a set but I couldn't find anyone is the USA that had them, I had to order them from Asia so they won't be here for 2 weeks:-(
Just Zach is offline   Reply With Quote
Old 09-15-2008, 02:52 PM   #15
Mic
Bottom shock mount bolts are 2mm. I added 2mmx20mm in order to out board teh shocks on the axel.
Mic is offline   Reply With Quote
Old 09-15-2008, 03:28 PM   #16
Link?
'04 Rubicon is offline   Reply With Quote
Old 09-15-2008, 03:34 PM   #17
u can get them on ebay im about to order a set. "then if u dont like them on ure mrc u can always use them for a scale build."
Opedopy is offline   Reply With Quote
Old 09-15-2008, 04:29 PM   #18
difflocker's Avatar
I have a set lying around....now I need a MRC!
difflocker is offline   Reply With Quote
Old 09-15-2008, 06:37 PM   #19
Just Zach's Avatar
Originally Posted by '04 Rubicon View Post
Link?
I got mine on ebay but here is a link for another place
http://www.toyeast.com/v3/pdtdetail....t_id=A02106925
Part number is MST-03/LB
Old 09-15-2008, 09:30 PM   #20
Back in the WATER!
dpdsurf's Avatar
Another link. hurry before I change my mind and buy a 2nd set:-P These were originally for my scaler that I'm in the process of restoring.
http://cgi.ebay.com/4Pcs-Alloy-F-R-S...2em118Q2el1247
