09-22-2008, 01:39 PM | #21 | |
Quarry Creeper Join Date: Jul 2008 Location: Lawton
09-22-2008, 02:08 PM | #22 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
Got to play with them the other day when John came by the shop. What fn they are! His modded one works great. Can't wait to get mine!!
09-22-2008, 02:13 PM | #23 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
09-22-2008, 02:36 PM | #24 |
Newbie Join Date: Sep 2008 Location: Celina
Hey Badger, what does turning the trans around do for you???
09-22-2008, 04:41 PM | #25 |
09-22-2008, 05:04 PM | #26 | |
I wanna be Dave Join Date: Feb 2004 Location: on a Big Rock
Note: I was running a Castle BEC set up powering everything at 6 volt @10 amps. I re-wired the BEC so it was powering only the steer servo, and dig servos quit dying. You should be fine. Last edited by Fishmaxx; 09-22-2008 at 05:19 PM. | |
09-22-2008, 05:19 PM | #27 | |
I feel much better now, thank you. | |
09-23-2008, 01:09 AM | #28 |
RCC Addict Join Date: Jun 2008 Location: Wasilla
| Thanks!
badger, took a couple of ure ideas ;D makes a huge diff. i tried the shocks mounted down low but do you think that binding will break anything? everything else helped/worked much better now i just need a new servo! heres a pic of my rig. (the black one on left) the one on the right is my buddies rig he 4 linked it. - tre |
09-23-2008, 06:29 AM | #29 |
John, are you running a cutoff with the stock esc with lipo ?
09-23-2008, 09:28 AM | #30 | |
Just don't tighten the screw down all the way and the lower shock mount shouldn't bind throughout the cycle. Mine seemed like it was going to bind a lot but once it's all together and I cycled the suspension it seemed very smooth and didn't feel like it was binding at all. Nope, I do the same thing in one of my Slashes, just pay close attention to the power and once it starts to drop, turn it off. These Mini Crawlers eat so little juice that you could run one pack for an hour and not even kill half the battery and swap it out for another if you are that worried about dropping the voltage to low. I have yet to even use my second battery though. | |
09-23-2008, 09:56 AM | #31 |
09-23-2008, 10:41 AM | #32 | |
Quarry Creeper Join Date: Feb 2005 Location: Indy-Westside
09-23-2008, 10:42 AM | #33 |
09-23-2008, 01:39 PM | #34 | |
haha i bet you do STD ;D | |
09-23-2008, 03:29 PM | #35 |
A friend and I just got done running my Losi MC's for around an 1 hour and 20 minutes. The micro servo is still working strong. So far the drive train on these have taken some serious abuse, we had the tires bound up several times and so far no breaks. |
09-23-2008, 11:12 PM | #36 |
So I put the Thunder Power 1320 mAh 2S Lipo that we crawled with for least 1 hour and 15 minutes today on the charger, it took 1258 mAh before it peaked. The only problem with having a Lipo in the crawler is having all the extra punch and wheel speed compared to the stock pack. My friend drove the modded rig most of the time today and he loved the extra power as well, he would punch it from obstacle to obstacle saying "he was rock racing". Not bad run time for such a small battery. |
09-24-2008, 12:45 PM | #37 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
hey badger.. what is the shock length,on the stock shocks? |
09-24-2008, 02:02 PM | #38 | |
but check out these 3 images man. http://farm4.static.flickr.com/3135/...1e91d8ee_b.jpg http://farm4.static.flickr.com/3234/...5a0acd01_b.jpg http://farm4.static.flickr.com/3014/...53af1001_b.jpg they have the sizes i measured for something... lol but i cant guarentee there exact, but damn close. hope it helps. - tre | |
09-24-2008, 02:38 PM | #39 |
09-27-2008, 11:02 AM | #40 |
Rock Stacker Join Date: Aug 2008 Location: Rock Springs
What are you using for traction compound?
