09-20-2008, 07:51 PM | #1 |
Newbie Join Date: Sep 2008 Location: Maple Valley
| I love my new money pit!!
Just fried my second 225 Mighty, watched as smoke rose from the back plate after like 3 minutes!! First mighty went with the stock ESC BEC but I now have a rooster crawler 12t. Replaced with the whinny stock servo and ran 30 minutes! Lots of power from the Hitec but I know I'm not the first one to do this. I feel like I just wasted $30 on a nice new METAL GEARED smelly box. I know asume the first Mighty fried the stock BEC and I'm just lucky my new Novak didn't! Just a warning for someone looking into this "upgrade" swap. Any body know were I can get a Lunch Box body? |
09-20-2008, 08:15 PM | #2 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
Geez, what are you doing with it, trying to pull your van?
09-20-2008, 08:36 PM | #3 |
Nope, just crawlin the side of the couch and table cuse it's rainin'. I do have a lot of weight but the stock servo didn't fry just makes a noise when loaded and warmed up after a couple of minutes. The stock servo never acually even gets warm. Both the Hitec's got hot. Last edited by MiniVan; 09-21-2008 at 02:50 PM. |
09-21-2008, 03:38 AM | #4 |
RCC Addict Join Date: Apr 2006 Location: On Da' Shelf
It seems that the 225mg servo is just not designed to be held at full lock for more then a few seconds? The servo works great in 12th scale pan cars and I ran both a 225mg and 225bb in my micro rs4 and never had an issue! And all the burn up stories I have heard of have been when the servo was being used in a setup that would call for it to hold a full lock position. Badger has been using an 82mg in his MRC with good results he said. |
09-21-2008, 09:10 AM | #5 |
RCC Addict Join Date: Jun 2008 Location: Fresno
rooster crawler in an mrc? kinda over kill dont you think ? to each his own i guess |
09-21-2008, 02:41 PM | #7 |
Definitly holding the servo close to lock at times but also lots of hard side load and back and forth, I would say standard crawin action though. As for the Rooster, more of a over kill at this time, but once rear steer, lipo, and a larger motor are all added it will equal out. The brake is awesome I do have to say. I will be making a full size servo mount front and rear this week, as well as mounting the frame hoops I made. I need to figure out how to post pics as I have tried to take pics through the process.
09-21-2008, 03:56 PM | #8 |
Rock Stacker Join Date: Sep 2008 Location: Under the bed
I just spent $160 on parts, available and not, at horizon hobby... My 4ws mini will be done in a week or two! |
09-21-2008, 07:41 PM | #9 |
Pebble Pounder Join Date: Aug 2008 Location: orlando
i burn the stock and two mighyminis also...built mount and stuck a mg645 hitech on it and haven't had a problem since......
09-21-2008, 08:27 PM | #10 |
Rock Crawler Join Date: Sep 2008 Location: Kennesaw
09-21-2008, 09:21 PM | #11 |
I just used the exploded view in the manual and ordered the parts from the front for the back. It was a lot easier than I thought it would be. I might be able to copy/paste my order, which will have several other things you may not want (I like to add extras to my toolbox just in case) but I think it should be pretty clear. |
09-21-2008, 09:22 PM | #12 |
Here we go: Line Item Description Qty Shippable Back Ord Price Extended 1 LOSB1419 Complete Screw Kit: MRC 1 0 1 $12.99 $12.99 2 LOSB1421 Servo Plates & Mounts (2): MRC 1 0 1 $6.99 $6.99 3 LOSB0822 MSX12 Digital Mini Servo: MRC 1 1 0 $28.49 $28.49 4 LOSB1422 Servo Saver & Arm Set: MRC 1 1 0 $6.99 $6.99 5 LOSB1409 Front Spindles & Carriers with Hardware: MRC 1 1 0 $7.99 $7.99 6 LOSB1410 Steering Links, Long & Short: MRC 1 1 0 $7.99 $7.99 7 LOSB0823 MSX12 Servo Gear Set 1 0 1 $3.99 $3.99 8 LOSB1441 Spring Cup & Shock Ends (4): MRC 1 0 1 $5.99 $5.99 9 LOSB1440 Assembled Shock (2): MRC 1 1 0 $15.99 $15.99 10 LOSB1447 Shock Spring Set, Soft (2): MRC 2 2 0 $2.99 $5.98 11 LOSB1420 Servo/LiPo Battery Plate, Carbon Fiber: MRC 1 0 1 $15.99 $15.99 12 LOSB1433 Front/Rear Metal Differential Locker (1): MRC 1 0 1 $12.99 $12.99 13 LOSB1435 Center Metal Diff Locker (1): MRC 1 0 1 $12.99 $12.99 14 FREIGHT Shipping and Handling 1 0 0 $7.99 $7.99 The only thing I was unsure about was whether I needed to order 2 diff lockers. The description is very vague. A few of the things on there were ordered because their individual parts (like the shocks) were on backorder and I have broken shocks that need to be fixed. The extra $ was worth not having to wait til it is 40 degrees out to use the truck again. |
