12-26-2008, 01:27 PM | #1 |
Rock Stacker Join Date: Nov 2008 Location: nor cal
| Big Jim's Snipe dMg Snipe...Widelock 1.9 3 piece rim...Outcroppers...HR 30 deg links...HR center gears w/locker...HR 62 tooth gear...HR Alum gear case...HR drive lines...HR c's and knuckles...HR alum skid plate coated in slippery tape...Losi 1 piece rear axles...Holmes mini TM...Tekin FXR...Losi carbon servo plate...Hi tec full size servo...losi little lipo...losi steel lockers in f & r axles...Metal steering links ( missing bottom one, broke plastic end!) Losi shocks 60 wt oil soft springs Just got er done!! |
12-26-2008, 01:33 PM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: Ramona
very nice rig.. where do i get all that hop ups and wheels?? Local hoby shop only has losi wheels for 120 bucks?!?!?
12-26-2008, 01:37 PM | #3 |
Check out the vender section...horizon for losi parts...rc4wd.com for the rims and tires...liquid for the hr stuff...and DMG for the chassis
12-26-2008, 02:02 PM | #4 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
great start . looking good . lots of upgrades should make it bulletproof |
12-26-2008, 05:08 PM | #5 |
Newbie Join Date: Apr 2007 Location: Marshalls Creek
Can you take a closer pic of the HR C and knuckles.
12-26-2008, 06:27 PM | #6 |
sure...they don't fit right though!!! you gotta mess with the brass sleeves...1 on top and one on bottow rather than both on the inside of the c's
12-26-2008, 08:10 PM | #7 |
Rock Stacker Join Date: Sep 2008 Location: Folsom
what battery is that. nice rig |
12-26-2008, 10:25 PM | #8 |
| LOSI 7.4 volt 600mAh 2S2P 20C LiPo $45 at horizon hobby...it's as big as an icecube |
12-26-2008, 10:42 PM | #9 |
12-26-2008, 11:23 PM | #10 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
That crawler looks like its "all business". Nice.
12-27-2008, 07:20 AM | #11 |
Pebble Pounder Join Date: Aug 2008 Location: the land of entrapment
| hey man are you going to put body panels on that? |
12-27-2008, 10:11 AM | #12 |
yeah...but havent found the good mix of body that does not take from the true tuber look
12-27-2008, 09:52 PM | #13 |
12-27-2008, 09:58 PM | #14 |
what sleeves? No drilling or bolt changes>>>went together like a snap
12-28-2008, 07:40 AM | #15 |
12-28-2008, 08:01 AM | #16 |
| I am running a hacked up tlt body for now.I also have a losi grappler and a losi bronco body.I think I am going to do something w/ the bronco.a little imagination goes a long way. |
