12-29-2008, 10:02 PM | #1 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
| Del Monte's MRC
Well, its taken me a while to post up this rig, partly because I'm lazy... but mostly since I've been having such a blast driving this little guy. This rig is decked out with all the Losi goodies 1.9 Aluminum rims Blue Compound Claws Aluminum Shocks Offset servo plate Losi Lipo Losi CV shafts I've tried quite a few different shock setups on this rig. What I've found worked best was limiting the shocks a bit with fuel tubing and running 30wt. oil all around. I've got 1/4" pieces of tubing under the piston inside the shocks, and on the shaft outside. The tires and wheels made a huge difference in performance and looks too. I'm running the supplied weights in the front rims, and this thing can climb now Of course, it has to match its big brother |
12-29-2008, 10:09 PM | #2 |
Pebble Pounder Join Date: Dec 2007 Location: Tucson, AZ
nice ride! how did you mount that servo plate?
12-29-2008, 10:18 PM | #3 |
The aftermarket servo plate mounts off the same holes as the stock plate. It just pushes the servo off to one side and makes room for that teeny little lipo.
12-29-2008, 10:36 PM | #4 |
Is that plate from Losi? if it is what is the part number for it? thanks
12-29-2008, 10:54 PM | #5 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
Clicky: http://www.horizonhobby.com/Products...rodID=LOSB1420 It's nice, I run the same set up on my DMG Nat. |
12-30-2008, 02:26 AM | #6 |
Rock Crawler Join Date: May 2007 Location: Corona, CA
Hey jake how is that servo working?
12-30-2008, 08:34 AM | #7 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
What else you have in that thing? What esc you running, what motor? I am curious cause I am thinking about running that lipo combo but you need a new esc I though? Nice 1:1 Did Losi sponsor you for that? |
12-30-2008, 11:27 AM | #8 |
Rig looks good Jake. Both of them Hope all is going well.
12-30-2008, 12:27 PM | #9 | |
| Its working great.. a lot more power then stock, although for some reason my stock Losi servo worked better on my old VF dig :-P Quote:
and yes, Losi is sponsoring our Ftoy for the 2009 season | |
12-30-2008, 12:53 PM | #10 |
Pebble Pounder Join Date: Nov 2007 Location: Fredericksburg
sick ride, I love the green. what servo is that? |
12-30-2008, 12:58 PM | #11 |
I believe it's a Hi Tec 5245MG Mini Digi...the analog version is the 225MG.
12-30-2008, 06:24 PM | #12 |
12-30-2008, 07:01 PM | #13 | |
The Heavies are 4.6 oz each, all up with Blue Claws and Losi memory foams...no additional weight added. | |
12-31-2008, 10:55 AM | #14 |
Badger weights the Losi beadlocks with a few others in this thread Losi 1.9 Aluminum Beadlocks for my MRC I was concerned with them being too heavy for the mini, but its perfect. This rig can just about keep up with my 2.2, except on big breakover stuff. |
12-31-2008, 10:57 AM | #15 |
12-31-2008, 12:19 PM | #16 | |
I saw that thread too and forgot all bout it | |
12-31-2008, 06:58 PM | #17 |
04-23-2010, 09:14 AM | #18 |
Lets see some updates Jake. |
04-23-2010, 09:24 AM | #19 |
no talent hack Join Date: Feb 2007 Location: Redwood City
