01-05-2009, 02:59 PM | #61 |
Newbie Join Date: Jan 2009 Location: San Francisco
Wow that looks awesome!!!! |
01-05-2009, 03:03 PM | #62 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
Yeah, which motor is it? Badass rig btw! Those rims are hands down the best looking for the mini. Too bad they are so $. :-( |
01-05-2009, 03:04 PM | #63 | |
RCC Addict Join Date: Feb 2007 Location: LRC
| Quote: | |
01-05-2009, 03:52 PM | #64 |
here are a couple of short videos I took in the yard http://s270.photobucket.com/albums/j...t=P1050697.flv http://s270.photobucket.com/albums/j...t=P1050695.flv http://s270.photobucket.com/albums/j...t=P1050693.flv http://s270.photobucket.com/albums/j...t=P1050691.flv http://s270.photobucket.com/albums/j...t=P1050689.flv http://s270.photobucket.com/albums/j...t=P1050687.flv http://s270.photobucket.com/albums/j...t=P1050686.flv http://s270.photobucket.com/albums/j...t=P1050684.flv |
01-05-2009, 05:50 PM | #65 |
Rock Stacker Join Date: Aug 2008 Location: michigan
howdoes this chassis compare to the mini slingshot? does it crawl better?
01-05-2009, 06:12 PM | #66 |
I have never crawled against a mini slingshot maybe soon we will be able to see |
01-05-2009, 11:11 PM | #67 | |
RCC Addict Join Date: Nov 2007 Location: CALI "209"
seen that you are not using stock esc. so did you run this motor with stock esc before upgrading are you using stock esc? with this motor. chassis looks great Last edited by finishline; 01-05-2009 at 11:14 PM. | |
01-06-2009, 04:35 AM | #68 |
01-06-2009, 07:33 AM | #69 |
Pebble Pounder Join Date: Dec 2008 Location: The Dirty Dirty, A-Town, ATL, The A, Hot-Lana, ATLANTA GEORGIA
I put one of these motors in last night with the stock esc and a 10 tooth pinion. Did have have to mod the motor plate and space to motor back a little. Also had to grind the splines off of the motor to make the 10tooth pinion fit. Has plenty of power but IMO you dont have the precision crawling that the stock motor gave. Another friend is running the motor w/ the Tekin B1R ESC and his feels the same way (we ran them side by side last night) With the stock battery and 2 ounces in the front wheels it will still pull wheelies. Gatekeeper. in your more experienced opinion, how did you feel about the low speed power and precision of the stock esc/ rx280 vs. how your setup now? |
01-06-2009, 08:03 AM | #70 |
yea I see what you are saying,mine still crawls fine if not better you just have to watch when you use the power .What is it doing at very slow speeds
01-06-2009, 10:38 AM | #71 |
Chassis looks great Austin, nice work |
01-06-2009, 11:48 AM | #72 |
Thanks I have been working on it for a while now
01-06-2009, 12:03 PM | #73 |
I just feel I dont have as much control at the lower speeds. Can't go slow enough and the power comes on too fast. I'm going to try to re-set the esc tonight and see if that helps. With an aftermarket esc i could set a custom throttle curve or maybe with a better transmitter it would help control it? Or maybe its just the motor can't turn as slow as I'd like it. When you do try to go as slow as possible you can hear and see it surge ever so slightly as well. I know what your saying about watching when you uses the throttle. If my 1:1 rig had that much go id need some more health insurance. |
01-06-2009, 02:55 PM | #74 | |
01-06-2009, 03:37 PM | #75 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
GateKeeper, do you know if these RX 280 motors are zero timing? Cause after flipping my trans I noticed that it didn't pull as hard in forward. I fliped it for battery placement but after running it flipped, the motor felt warmer than usuall. I installed the trans back as oe and placed the battery on the rear upper tri link. I thought it would hinder climbs being in the rear but still pulled off some awsome climbs. Even on wet rock. The truck has now very low CG and is almost perfectly balanced verse front to rear and side to side. I believe this helps.
01-06-2009, 05:53 PM | #76 | |
01-08-2009, 07:18 PM | #77 |
Rock Crawler Join Date: Oct 2008 Location: Somewhere near the lake in IL
First off let me say you driving skills are great to watch, I'm a noob to RC crawling but impressed none the less! I'm running a DNA mini SS right now but the day that your chassis is available I'm ordering. Any ideas on pricing?? my paypal is waiting on you bro. Great work! |
01-08-2009, 08:27 PM | #78 | |
I should know something tommorrow I hope | |
01-08-2009, 11:33 PM | #79 |
Rock Crawler Join Date: Feb 2008 Location: Anniston, Alabama
Guys, let me tell you. I got to drive this rig for a pretty good while last week-end and it is VERY impressive. Even with me driving it it was able to pull off some wicked lines. (Austin drove it OK also) It is very capable and predictable. i cant wait for it. |
01-09-2009, 08:23 AM | #80 |
Rock Stacker Join Date: Oct 2008 Location: gainsville
| gatekeeper
PLEASE HURRY Can I prepay ? I want one fast.
