| | #1 |
| RCC Addict ![]() Join Date: Oct 2005 Location: Trussville, AL
| This is a prototype version of the mini gc2. Production types will be aluminum Specs: Stainless steel lowers (stock length) uppers are threaded rod with traxxas rod ends (stock length) losi late model shocks (modified) losi cvd's Hot racing axle diff lockers Losi trans locker losi slider motor stock losi esc Mini-t bug body narrowed/reduced panthers DNA 1.9 snipers (waiting on them, thanks Don) hitec 5955 stock tx/rx ![]() A nice clean cut skid with everything drilled and tapped perfectly to triangulate the lower to eliminate axle swing ![]() Look at how narrow it is ![]() Before the cvd's became available, I looked and realized there was room to shave the cups on the axle stubs and still be strong. So after a little bit of surgery ....... ![]() MUCH BETTER!!! but the cvd's will allow for more than that Note, the front servo/upper link mounts will be similar to what you see but a lot nicer and more precise cut (these were cut by hand) With the way that Gatekeeper designed to mount the upper links, he used 2mm rod ends ............... So my fix since I didnt have anymore was to make my upper links from 6/32 all thread and sleeved with carbon fiber rod (still need to do the fronts). I cut them to the same length as the lower links and redrilled all mounting holes to 3mm. You will have to shave the side of the rod end so that it will fit in the correct mounting position and not rub against the upper link mounts on the axle Last edited by yukon635; 01-15-2009 at 02:19 PM. |
| Sponsored Links | |
| | #2 |
| So I picked up some Losi late model shocks at the LHS and realized they were way too short. Here is my fix to make them work First take your stock shocks and take them apart. You will need the stock shock shaft. Second take apart the losi shocks and take the shaft out. Then remove the e-clip from the stock shock shaft and replace the stock shock piston with the Losi piston. Place the e-clip back on and put the Losi shock back together. Losi piston on the right and the stock mrc on the left ![]() Next screw the adjustable nut on the shock body all the way down to the lowest position possible. Then take the largest stock mrc shock adjuster spacer (??) and place it below the nut Here is what it should look like ![]() Put your shocks back together and bleed them. End product compared to stock Losi late model shocks. The late models are originally around 55-56mm from eye to eye. After modifying these, they end up being around 66-67mm from eye to eye. This will give you around 2" of belly clearance depending on how you mount them ![]() For some reason I can't find my other two stock shocks so, I cant put the other two together until I find them Last edited by yukon635; 01-14-2009 at 07:24 PM. |
| | #3 |
| | #4 |
| Quarry Creeper Join Date: Feb 2006 Location: Surrey B.C Canada
| Thats a sweet little rig bud!! Well done |
| | #5 |
| RCC Addict ![]() Join Date: Feb 2007 Location: LRC
| Have you been running it much |
| | #6 |
| thanks Not since this past weekend with you. I have been reducing those huge tires |
| | #7 |
| Moderator ![]() Join Date: Apr 2004 Location: In my head
| Looks god Kevin I just ordered a bunch of parts for mine!!! |
| | #8 |
| New Papa! ![]() Join Date: Dec 2008 Location: With the ATL Crawlers
| I've been wanting to ask this. I noticed that on other venders chassis they offer more shock locations for tunning. I know Gatekeeper wouldn't put this chassis in production w/o all the R&D. Do you think this is the best shock location for the MRC since its doing the most damping. I know alot of guys are practically laying there shocks down. How does that let the shock do it's work |
| | #9 | |
| Thanks Joey, yeah i have a bunch of stuff on the way right now. Gotta love these little things. Quote:
I have seen a lot of people lay the shocks down. The more you lay them down, the softer the suspension is and from what I have seen the suspension doesn't act right to me (at least that is what I saw when playing around with one of my old supers) Hope that helps some, maybe Austin will chime in on this subject | |
| | #10 |
| RCC Addict Join Date: Apr 2007 Location: RAMBLIN
| can you walk me through how you moded the cups for more steering . i need this mod. |
| | #11 |
| | #12 |
| thanks dude cant wait to get mine build up. |
| | #13 |
| Newbie Join Date: Dec 2008 Location: buffalo
| x2 on the steering! |
| | #14 | |
| | #15 |
| Yeah. I had no doubt that it is the best shock location for this chassis. It still puzzles me how well these chassis perform. After seeing these things rock at stone mountain I've been messing with my stock chassis. And I see the stock chassis is not going to cut it anymore now that your taking pre orders. |
| | #16 |
| It is working well maybe you will pre order one |
| | #17 |
| | #18 |
| i like the bug body. is it long enough to be comp legal? |
| | #19 |
| ✘ ɹǝʞɔɐʇs ʞɔoɹ ✘ ![]() Join Date: Jun 2008 Location: Wasilla
| Kevin, it looks like a mini gate crusher man! the BRP fun wons "da bug" body meets comp specs not sure about the losi one. - Tre |
| | #20 |
| 2.1.2.2 – 1.9 Class body must be 2.75” minimum height on sides. No less than 9” total length and full original width, and no less than 3” in the center. All bodies should resemble its original form (Jeep bodies look like a Jeep) well crap, I just looked at the rules and this body is 2" too short in length here is what the body measures 7.0" x 3 3/8" x 2 3/4" Last edited by yukon635; 01-15-2009 at 04:41 PM. |
| Thread Tools | |
| Display Modes | |
