Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: losi aluminum shocks
Old 01-18-2009, 08:36 PM   #1
Default losi aluminum shocks
I bought the losi aluminum shocks filled them with oil and there leaking. I've taken them apart and can't find the problem. Does anybody have any possible solutions?
j_ride008 is offline   Reply With Quote
Old 01-18-2009, 08:41 PM   #2
What's In The Box!!!!!!!
Lil Jon's Avatar
is the little clear plastic gasket seated where it should be. mine dont leak at all.
Lil Jon is offline   Reply With Quote
Old 01-18-2009, 08:51 PM   #3
Did you follow the directions??
If you tightened the cartridge like stated, they shouldn't leak.
I have yet to have any of my Losi shocks leak.
silvr_tung_devl is offline   Reply With Quote
Old 01-18-2009, 09:13 PM   #4
i did tighten the cartage. i think its the little clear gasket. when tightening the cartage it slips out of position.
Old 01-18-2009, 09:15 PM   #5
I had the same issues with my Mini-t shocks, followed the directions to the T and they still leaked. I ended up using 2 of the clear seals in each shock and it seemed to solve the problem. Dang, I was hoping losi fixed that issue, I have a set on order from the lhs.
fixed13 is offline   Reply With Quote
Old 01-18-2009, 09:29 PM   #6
binaryterror's Avatar
The best fix is something that bypasses that lower cartridge leak.
1. Use black RTV sealant (just a little) on the cartridge and seal that thing in.
2. Fill from the top and bleed as if it was an Associated or Kyosho 1/10th scale buggy shock.
I had nothing but problems running Mini-T shocks. Even at one point sent them in to Losi's service who filled them and sent them back...they leaked in the box.
binaryterror is offline   Reply With Quote
Old 01-19-2009, 04:32 PM   #7
I have had no issues with my shocks. I run them hard and no leaks. Worst part was when I was re assembling them and had to deal with the e-clip.
Sinagua is offline   Reply With Quote
Old 01-19-2009, 06:50 PM   #8
Well the directions state to tighten them half to a full turn!
I just couldn't take the chance that they'd strip, so I tightened mine until the clear gasket started to slide out, then stopped.
Sorry, I shoulda stated that in my earlier post!
