Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Like Tree1Likes
Thread: My Sami a.k.a. Madzuki
Old 01-18-2009, 11:41 PM   #1
MadDogRC LLC
Mad4Rnr's Avatar
Default My Sami a.k.a. Madzuki
This is my second MRC and since the first one was a comp rig this one will be a scaler.
I want to keep this build pretty simple but still want it to work well and appear relatively scale.
To start I picked up some goodies including:
  • Black Losi MRC from Jake's Performance Hobbies (JPH)
  • L-trail chassis from TCS
  • Losi Late model aluminum shocks from JPH
  • Fast Eddie's "Master Builder's Spacer Kit" from JPH
  • Suzuki Samurai body from Genki DoriDori
I'm super excited about the spacer kit from Fast Eddie's, it has 10 each of six different sizes
The spacers are nicely machined, this kit will come in handy on many different builds in the future!
I quickly mocked up the chassis and shocks, I think they should work out alright
With body cut on stock lines:
Mad4Rnr is offline   Reply With Quote
Old 01-18-2009, 11:43 PM   #2
Lookin good!
Scott
po' riggity is offline   Reply With Quote
Old 01-18-2009, 11:46 PM   #3
Axial Team Driver
Brandon's Avatar
Sweet! Another MRC scaler
Brandon is offline   Reply With Quote
Old 01-19-2009, 10:36 AM   #4
JPH Racing's Avatar
Off to a great start!!!
JPH Racing is offline   Reply With Quote
Old 01-19-2009, 11:27 AM   #5
Looks great! I am going to have to check out that spacer kit.
What color are you thinking about?
-Lex
Lextronix is offline   Reply With Quote
Old 01-19-2009, 11:51 AM   #6
MadDogRC LLC
Mad4Rnr's Avatar
Thanks guys, I'm going black body with a tan top on this one
got a surprise for the wheels as well
Old 01-19-2009, 06:15 PM   #7
TEAM RCC
bcrofts's Avatar
looking good looks like i need to come over and see it
bcrofts is offline   Reply With Quote
Old 01-19-2009, 06:37 PM   #8
MadDogRC LLC
Mad4Rnr's Avatar
I don't know about that, this build is for people who don't drive bergs!
Old 01-20-2009, 07:54 AM   #9
Looking forward to watching this build. I was thinking about getting a Axialscaler, but with one MRC in the house, I might as well just buy another MRC and a L-Trail frame. Then my 4 year old son will have his own to drive and I might get to drive my soon to be built mini gatekeeper.
Keep posting the progress on the build!
Sinagua is offline   Reply With Quote
Old 01-20-2009, 07:58 AM   #10
ΜΟΛΩΝ ΛΑΒΕ
chip cross's Avatar
I can't wait to see your Sami finished up. That FastEddy master builder's spacer kit is sooo sweet and has a great price.
chip cross is offline   Reply With Quote
Old 01-20-2009, 08:23 PM   #11
Mad4rnr,
After looking at your build earlier today I had a few questions come to mind:
What is the maximum wheelbase that the L-trail can be built to?
Why are you going with the late model shocks instead of the MRC aluminum shocks?
What length and how many spacers/crossmembers are you using between the frame rails? (I figured 71mm with the 6mm per side that TCS suggests)
What material are you going to use for the crossmembers?
Sorry for all of the questions.
Old 01-20-2009, 09:37 PM   #12
Nice Start!
Man I need another MRC!
Xtant3150c is offline   Reply With Quote
Old 01-20-2009, 11:40 PM   #13
MadDogRC LLC
Mad4Rnr's Avatar
Originally Posted by Sinagua View Post
Mad4rnr,
well i can't answer all your questions because this is currently where the build is:
I will try though:
1) not sure on the max wheelbase, looks like the chassis is setup perfectly for the stock 8.5 wheelbase as the minimum (should be good for up to 10" maybe Harley can tell you more)
2) for the chassis width I've been playing with keeping it at the stock 60mm width that way I can run the Losi late model shocks on the outside of the chassis, need to make new upper and lower links to make this happen though
3) the reason I went with the shocks is that they are short for a lower stance more suited to the sami
4) In general for crossmembers I always build with Delrin, usually 3/8" for skids and 1/4" else where, here though I will use the 1/4" all around and alos throw in some Axial 60mm links to stiffen the shock towers
Old 01-21-2009, 06:20 AM   #14
Thanks! I just want to get all of the info on building up a L-trail before I get all fired up before hand and then have reality smack me up side the head.
Old 01-25-2009, 09:33 PM   #15
nice body choice i love samurais
ddizlle28 is offline   Reply With Quote
Old 01-25-2009, 09:36 PM   #16
Where did u get the samy boddy
Old 01-25-2009, 10:29 PM   #17
MadDogRC LLC
Mad4Rnr's Avatar
from, Genki:
http://www.genkidoridori.com/index.p...roducts_id=833
Have some updates for you, so I decided to switch things up with the front suspension when I found out that the X-trail proto springs fit perfect on the L-trail chasis.
Here is the a pick of the package I found in my RC Crawler stash:
I thought these springs made the X-trail sit a bit low for the but love how they work on the MRC. I didn't even have to drill any holes to fit them up.
I Click the image to open in full size.
I made some little spring blocks from delrin. In this pic only one screw is there but I will end up using both the upper and lower screws to hold the block to the axle. I still have to incorperate the shock mounting as well
I also mad fabbed a new skid plate and kept the chassis at the stock 60mm width. I need to start on the rear four link tomarrow
Old 01-25-2009, 10:35 PM   #18
This is looking real good, great find on the leafs. Keep up the great work. I have not been sold on the Zuki but the more I see the more I like it.
fixed13 is offline   Reply With Quote
Old 01-25-2009, 10:42 PM   #19
i cant find the spacer kit on the web site could you give me the link on there web site on where they are at thanx
scaleerdad is offline   Reply With Quote
Old 01-25-2009, 10:51 PM   #20
MadDogRC LLC
Mad4Rnr's Avatar
just check out this thread
http://www.rccrawler.com/forum/showthread.php?t=154339
