| | #1 |
| Rock Stacker Join Date: Jan 2009 Location: Akron
| I have been seeing so many options for shocks, and now that my new chassis should be here soon I thought I'd look into them. So far I know of: -stock shocks -losi aluminum MRC shocks -mini-t shocks -late model shocks -stocks with internal springs (droop) So out of all of those which would you think is the best choice for performance? Thanks |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Sep 2008 Location: Ukiah
| Aren't the mini late models and the threaded aluminum the same if not im stupid |
| | #3 |
| Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
| if I where to do it again and I might, I will go with the Losi late model alum shocks, I have the Losi alum MRC shocks and have them so limited, like just about everyone else there's no point in havng them, if your looking for articulation that you'll never use then go with the Losi mrc alum shocks, if you want something practical go with the Late mdoel alum ones. |
| | #4 |
| Alright so late model is looking good so far. What about alum MRC shocks with an internal spring droop setup? |
| | #5 |
| Newbie Join Date: Sep 2008 Location: rocksprings
| I would run the losi aluminum if i were you but that's just me. |
| | #6 |
| Newbie Join Date: May 2008 Location: Jersey Shore BAR's (BIG ASS ROCKS)
| | #7 |
| Rock Crawler Join Date: Jan 2007 Location: Lehigh Valley
| Mini Late Model shocks Good ride height & plenty of articulation. ![]() Here is my post, Mini Late Model shocks I have since spaced out the uppers shock mounts so there is no binding. They work great and are smooth |
| | #8 |
| Pebble Pounder Join Date: Dec 2008 Location: Tomball, Tx
| I had bought a set of the MLM shocks, but they felt too short. Currently working on a goofball hybrid of vendetta ST shock body/piston/spring and MRC shaft w/ internal and external limiters. |
| | #9 |
| look great.............. jmz6 have a question on the upper mounts. Is that in-board mounted on the uppers and how far in with the spacers. I may bring them in about 10mm with a 4-link, not to sure if it will bind, will lower the 4-link mounted to the side frames as needed, just above the lower link mount. |
| | #10 |
| Rock'n'Roll Sherpa ![]() Join Date: Mar 2006 Location: Were the Army sends us!
| Also have the LOSI Aluminum Threaded Shocks...they are realy nice but in my mind,way too much articulation...even with the provided spacersinstalled..but hey,can't always win |
| | #11 |
| Don't you ever have any problems with the lower ground clearance? It seems like you would hook up on every rock you crawled over. |
| | #12 | |
Stock locations on the axle and the black plastic chassis plate. I used 1/4" bushings to space the shocks out and small brass bushings that fit in the upper shock mount hole. I will snap a pic in a few | |
| | #13 |
| | #14 |
| Rock Stacker Join Date: Dec 2008 Location: Richmond Hill,GA
| Maybe I'm thinking incorrectly,but I need more articulation.I have the mini LST shocks and I can't seem to get them soft enough.I feel like I'm driving a scale rig now. |
| | #15 |
| Quarry Creeper Join Date: Jan 2009 Location: Sandpoint
| if you buy the aluminum threaded mrc shocks for it does it make it sit lower?? |
| | #16 |
| Quarry Creeper Join Date: Jan 2008 Location: siloam springs, home of the Mid West Challenge 2010
| I went with the threaded Mini lst shocks (ebay 23.99) and it lowered my height a little and are very adjustable. They comped well for me. |
| | #17 |
| ok cool thanks for the heads up |
| Thread Tools | |
| Display Modes | |
