Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: Motor? and Twist problem??
Old 01-20-2009, 01:41 AM   #1
Default Motor? and Twist problem??
Hey, just want to find out what motor and esc combo would be great for MRC? I am running LIPO battery with 20c brusting power, 30c max.. on stock losi rock crawler motor and esc. but looking to upgrade it with my futuba 2.4 tx and rx.. My next upgrade on it would be metal lockers, servo plate, and change it from 3 to 4 link??
Also the twisting issue... my front right wheel normally comes off ground too many times, is this cause with too much drop travel? also the body/chassis leans to left side , make it difficult to turn left.. should i change the shocks without coils over them, running pen style springs? with limit drops fuel tubing?
DirtyDezPirate is offline   Reply With Quote
Old 01-20-2009, 02:30 AM   #2
lowridinjuggalo's Avatar
we put 35 wt. 0il in the left rear and 30 in the rest and added a few extra clips 0n the left rear seems t0 help al0t
lowridinjuggalo is online now   Reply With Quote
