| | #1 |
| Quarry Creeper Join Date: Nov 2007 Location: Northern
| Would it be ok if I were to charge the stock 1100mah battery on my piranha charger? Seem slike 5-6 "suggested" hours on the stock charger is ridiculous. |
| Sponsored Links | |
| | #2 |
| Rock Stacker Join Date: Oct 2008 Location: Richmond
| I never really used the stock charger but a good rule of thumb is you can look at the mA output on the charger and divide that number by the mah of the battery and determine how long it will take to charge (example if it was a 100 mA charger then it would take 1 hour to charge a 100mah battery). 5-6 hours might be correct if it is a 200mA output charger on a 1100mah battery. Last edited by Uniballer; 01-20-2009 at 02:43 PM. Reason: didn't make sense |
| | #3 |
| Rock Crawler ![]() Join Date: Nov 2007 Location: somewhere
| | #4 |
| Quarry Creeper Join Date: Mar 2005 Location: hudson (the big city)
| it would be fine to charge it on your pirahna charger. if you have an adjustable rate selection on your charger then charge it at a low amperage for the first charge. maybe at .5A. then charge it at 1.1A from there on. |
| | #5 |
| Agreed, I typically charge mine at 1 amp and the battery is slightly warm afterwards. I would not go above 1.5 amps as I imagine those sub-c's will get rather toasty. |
| | #6 |
| RCC Addict Join Date: Apr 2007 Location: RAMBLIN
| i believe the cells are 1100mah 2/3 a . not sub c. but i charge mine on my hyperion charger at 1.1a and it charges in an hr or less. i have bumped it up to 1.5a with no ill effects.but i like a slower charge. |
| | #7 |
| i charge mine at 1.9 it takes b0ut 25 mins i talked t0 ass0ciated when i use t0 run dirt 0val and they t0ld me 0n the rc18b packs witch are the same as the l0si cralwer packs n0t t0 g0 0ver 2 that 2 was fine but the wa0uld n0t charge them 0ver 2 |
| | #8 |
| Your right they are not sub-C. Slower is typically better. |
| | #9 |
| Newbie Join Date: Feb 2009 Location: Rochester
| Sorry to drag up an old thread, but it seemed relevant. I am new to the electric scene, a diversion from my nitro truck. Here's my question. The CX-10 Piranha charger I have has a charging rate of 2.5A. Is this to much for the stock pack? I don't want any fires, etc. |
| | #10 | |
| Chief of Slapaho tribe. ![]() Join Date: Aug 2008 Location: Slapaho, Hawaii
| | #11 |
| I suppose a new charger is a better investment over replacing batteries all the time. |
| Thread Tools | |
| Display Modes | |
