Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: I need steering links and chassis spacers!
Old 01-20-2009, 05:45 PM   #1
Default I need steering links and chassis spacers!
I'm REALLY new to all this. I love my mrc, and have done quite a bit to it, now I want to change to metal links for the steering as I hit them way too much. Who makes these? My lhs doesn't have any. Also, I have a l trail chassis I want to build, but I need some crossmembers, where could I get those?
jamesart86 is offline   Reply With Quote
Old 01-20-2009, 06:00 PM   #2
There is one person on here that I know of that makes stainless steel steering links. The only problem is I and many others have been trying to contact him for weeks with no response. And I forget his name, sorry haha.
xonikcocker is offline   Reply With Quote
Old 01-20-2009, 07:02 PM   #3
I am going to be doing a L-trail build in a couple of weeks also. For the stainless links and possibly the crossmembers look up/pm JSSuper of CR/CC. Cody will take a bit to get back t you but should be able to help out. You can also find him by doing a search in the vendor section under tidbits. I am going to be ordering 2 sets of steering linkage from him.
As for the spacers for the build do a search for FastEddy. They have a set of spacers. http://www.teamfasteddy.com/
Hope this helps out.
Sinagua is offline   Reply With Quote
Old 01-23-2009, 11:23 AM   #4
Spacer kits are ot available direct.
RPP and JPH both have them in stock.
FastEddy is offline   Reply With Quote
Old 01-23-2009, 02:08 PM   #5
Integy now offers aluminum or stainless steering linkage, can't remember which.
flexmonger is offline   Reply With Quote
Old 01-23-2009, 04:44 PM   #6
WarTrader's Avatar
If your looking for a chassis cross member kinda spacer you can take a look at axial. They have spacers available from 1mm to over 65mm. Try here just look through the pages http://www.amainhobbies.com/index.php/cPath/1_24_831
hope that helps!
Fasteddys spacer kit is great! But I think your looking for something to act as a cross member between the chassis plates ??
As for the steering give cody a shout at CR/CC you can find his stuff here http://www.rccrawler.com/forum/showthread.php?t=145449
WarTrader is online now   Reply With Quote
