| | #1 |
| Newbie Join Date: Dec 2008 Location: USA
| I have a set of dna beadlocks and was wondering are you guys drilling through the wheels or the tires to let the tires breathe?? |
| Sponsored Links | |
| | #2 |
| Power of the Portals ![]() Join Date: Feb 2004 Location: where ever the wind fawkin blows me, tx
| I burn holes into my tires. |
| | #3 |
| Pebble Pounder Join Date: Jun 2007 Location: Harrisburg
| I put the vents in the tires. I just felt bad even thinking about drilling such a great looking wheel. |
| | #4 |
| I wanna be Dave ![]() Join Date: Jan 2004 Location: Detroit
| Yup I also vent the tire. Air going out the wheel or vent hole needs to pass through the foam. Air will more easily escape out the tire since not all the air is forced through the foam. |
| | #5 |
| Billet Freak ![]() Join Date: Jun 2007 Location: Earth
| I too vent the tire. It seems to react better to me than venting the wheel. The other advantage is if (when) you run it through any water, you can easily drain the water from the tire whereas if you vent the wheel, you have to pull the tire off the wheel in order to drain it completely. |
| | #6 |
| RCC Addict Join Date: Apr 2007 Location: RAMBLIN
| like everyone else here ,,i vent my tires as well. a $15 set of tires is better than a $100 set of wheels imo. i use an old soldering iron and put 2 holes opposite each other. never had an issue with any 1.9 2.2 or super tires. |
| Thread Tools | |
| Display Modes | |
