| | #1 |
| Quarry Creeper Join Date: Dec 2008 Location: Bend
| thanks, Jeff |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Sep 2008 Location: Where there are no rocks.
| I've had the stockers off and on again 3 times. So far so good. All i do is put a little tension on the tire, pluuing it away from the rim and slide a exacto blade along the rim as close as i can get it. leaves a little rubber behind but not to bad. maybe theres a better way but it works for me |
| | #3 |
| I wanna be Dave ![]() Join Date: Jan 2004 Location: Detroit
| Boil them in water for 10 minutes. Let cool and they should pop right off. |
| | #4 |
| RCC Addict Join Date: Apr 2007 Location: RAMBLIN
| | #5 |
| RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
| | #6 |
| | #7 |
| so if i boil them for 10 min....this wont like melt the wheel? sounds like a silly question but i dont know.... |
| | #8 |
| TN State Champ 2011 ![]() Join Date: Oct 2008 Location: Chattanooga
| No... the melting point of plastic is higher than the boiling point of water. |
| | #9 |
| Quarry Creeper Join Date: Sep 2008 Location: Ukiah
| one good idea DONT USE A HEAT BLOWER i did it and partially melted a hex had to reheat and mould around a 12mm hex bolt thank god i had one |
| | #10 |
| Rock Stacker Join Date: Sep 2008 Location: Memphis
| I took a knife too it. |
| | #11 |
| Quarry Creeper Join Date: Nov 2007 Location: Northern
| I did both the boiling and cutting technique. Be careful boiling the tire. I noticed the tire compound really becomes soft. If you boil, grab any part of the rim, not the tire. I used a pair of tongs to remove the wheel and noticed the tongs were damaging the tire from grasping. |
| | #12 |
| Should have added that I did the "Drink a lot of beer" way of getting the tires off. Lets just say that the stock tires are not usable, lol. But they came off! |
| | #13 | |
| Newbie Join Date: Jan 2009 Location: Colorado Springs
I managed to get the stock ones off, clean the wheel, add weight, put in the PVC bead lock mod, and get the stock tires back on. When I was taking it off, I was pulling on the tire to stretch a little, then go a little at a time and cut them off, which of course did leave some glue and a tiny bit of rubber behind, but nothing that time and X-acto blades couldn't fix. | |
| | #14 |
| Well Sinaavi, we'll see those talents put to the test at the comp you WILL be going to!!! |
| Thread Tools | |
| Display Modes | |
