02-09-2009, 06:28 PM | #1 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
| SVEN's Mini GC2
Not much of a build thread, because I built it Saturday during the Alabama Little Rock City competition (Thanks Austin!!). Not sure what place I came in, but I know I finished all the courses. Parts of the course I had tried to climb 2 weeks ago with a tuned stock chassis and could not even start the climbs. This time around, with out any practice on the setup, the truck went right up no problem. The goods: Gatekeeper Designs Mini GC2 chassis MaxAmps 860mah Lipo Holmes Hobbies TorqueMaster Mini DNA 1.9 Assassins Losi 1.9 Claws (blue compound) Losi CVD's (front only) 3 Racing MLST shocks Tekin FX-R Hitec 7955 servo Nomadio React From The Crawler Store: Aluminum Knuckles Aluminum Axle C's Front and Rear Diff lockers The body is held on with velcro straps because I can't stand side posts and needed something easy. Top mounted body posts will be made when I get a chance. I set the truck up with the stock shocks as that was what I had with me at the comp. I will update the pics when I get the 3 Racing shocks mounted up. To use the stock shocks, I used the hardware provided with the GC2 and a slice of fuel tubing between the shock and the chassis. The TorqueMaster Mini has excellent low speed throttle control on the 7.4V 860mah MaxAmps lipo. The motor is faster than stock, but not as fast as a Mini Slider motor with the same stock gearing. The lipo fits nicely on the Front top links. The FX-R is cradled in between the Rear top links. Last edited by SVEN; 02-10-2009 at 06:33 PM. |
02-09-2009, 06:32 PM | #2 |
Looks great SVEN. I need to build up a comp mini before ECC. Sure looks like a good start to me.
02-09-2009, 06:34 PM | #3 |
RCC Addict Join Date: Dec 2007 Location: Ward, SC
looks good anyways!
02-09-2009, 06:35 PM | #4 |
RCC Addict Join Date: Feb 2007 Location: LRC
I am glad you like it Sven ,I had my score sheet in my pocket when I got home:-(I guess we should of turned them in.Thanks for all your hard work |
02-09-2009, 06:38 PM | #5 | |
I hear this thing performs great, can't get Fish to shut up about it (like thats hard though) | |
02-09-2009, 06:41 PM | #6 |
Yea I will give you some driving lessons at ECC |
02-09-2009, 06:42 PM | #7 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
Great looking rig! What's the width with the Assassin's?
02-09-2009, 06:45 PM | #8 | |
Thanks for letting me help with it, I have really enjoyed it. 7.345 inches - measured from outside of tires. Last edited by SVEN; 02-09-2009 at 06:47 PM. | |
02-09-2009, 07:28 PM | #9 |
Newbie Join Date: Jul 2007 Location: South Central Texas
Hey nice rig, I was wondering can you run that motor with stock battery, if not what battery do I need? Thanks Zach |
02-09-2009, 07:41 PM | #10 | |
Thanks Harley. Yes, you NEED one of these. They are the best 'couch crawlers' around . You know, for those rainy days. Oh and comps too. | |
02-09-2009, 07:49 PM | #11 |
02-10-2009, 07:15 AM | #12 |
RCC Addict Join Date: Apr 2008 Location: Old Hickory
Nice! here's some shots at the last gtg. Cya at the next comp Not sure if you had the new chassis in these shots or not. |
02-10-2009, 08:55 AM | #13 |
Moderator Join Date: Apr 2004 Location: In my head
Nice Sven! I hope the mailman brings mine soon!!!
02-10-2009, 09:19 AM | #14 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
02-10-2009, 12:07 PM | #15 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
02-10-2009, 06:20 PM | #16 |
Rock Stacker Join Date: Aug 2008 Location: michigan
02-11-2009, 09:03 PM | #17 |
Made some new upper links out of some turnbuckles I had laying around. I just re-drilled the mounting holes to accept the 4-40 hardware. The chassis was designed so that you could use the stock links and still have the rear axle clocked up a little. I wanted just a tiny bit more, so the rears are barely longer than the fronts. I couldn't find a good way to mount the MLST shocks, so I stripped the Mini-T. I put the stock shock rod ends and spring cups on the Mini-T shock shafts. The springs are just the softest ones I could round up. |
02-11-2009, 09:09 PM | #18 |
Looking good Sven |
02-11-2009, 09:33 PM | #19 |
Rock Crawler Join Date: May 2007 Location: Glendora
Just wanted to know what direction you plan on going to fight the torque twist? oil? springs? preload spacers? I have the threaded aluminum shocks with 40wt in three and 50wt in the right rear and a stiffer spring to fight it, yet it is still is a problem.
02-11-2009, 09:36 PM | #20 |
| The link geometry takes care of most of it with this chassis |
