Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: my crawler died - need help
Old 02-14-2009, 08:07 PM   #1
Default my crawler died - need help
My crawler died on me tonight. Everything stopped working . No light on the speed control and no light on the receiver.
if I unplug everything from the speed control the red light starts flashing but nothing works.
I tried to bind the radio and receiver . The light on the back of the control blinks then goes solid but no lights on the receiver.
Doe's anybody have any ideas.
I'm running the stock motor and electronics.
Thanks Jeff
RallyeX is offline   Reply With Quote
Old 02-14-2009, 08:19 PM   #2
Live,Eat,sleep RC
RcBro's Avatar
try changing your transmitter batteries.
RcBro is offline   Reply With Quote
Old 02-14-2009, 08:20 PM   #3
you might have lost the bind with the radio also. In your kit is a little plug with the wire. If you turn on your trck before the radio they won't bind.
TK-twister is offline   Reply With Quote
Old 02-14-2009, 08:25 PM   #4
I put new batteries in the controller and a freshly charged batter in the crawler. Turn both of them on and nothing. The green and red light are on on the controller but the crawler is dead.
Thanks
Jeff
Old 02-14-2009, 08:29 PM   #5
I have tried to re bind. The light on the back of the controller blinks then goes solid but not lights on the electronics in the crawler.
If I unplug the receiver from the speed control the red light in the speed control starts blinking. If I plug the receiver back in the light stops.
Thanks
Jeff
Old 02-14-2009, 09:47 PM   #6
did you run through any water?
223voodoo is offline   Reply With Quote
Old 02-14-2009, 09:57 PM   #7
Esc died. Mine did the same thing was running a full size servo. Upgraded to a brushless system and never looked back.
dezslash is offline   Reply With Quote
Old 02-14-2009, 11:32 PM   #8
I had this happen to me too, so I ordered all new electronics. I wanted to replace them any how.
Jason S is offline   Reply With Quote
Old 02-15-2009, 01:27 PM   #9
Mr. Ed's Avatar
Thanks
Jeff
Call Horizon they will be quite helpful and if there is a defect in your electronics they will make it right. It's worth the call
Mr. Ed is offline   Reply With Quote
Old 02-15-2009, 11:37 PM   #10
I agree. If the truck stopped working because something failed they will replace it. Losi's customer service is as good as it gets!
Old 02-16-2009, 12:17 AM   #11
Thanks for all the help. I'm going to give them a call and see what they can do.
Thanks
Jeff
