Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: Were to get 5/32 stainlesssteel for links
Old 02-15-2009, 02:40 PM   #1
Default Were to get 5/32 stainlesssteel for links
Were can i get some stainlesssteel in 5/32 size for some steering links for my losi mrc. Stock ones got to go they hit way to much, yesterday that the comp i got stuck on the stock steering link a couple of times.
zr600 is offline   Reply With Quote
Old 02-15-2009, 05:36 PM   #2
Do you mean 6-32?
Your local hardware store might have SS, but Home Depot & Lowes carry reg steel allthread. What about 3mm from your local hobby store?
jmz6 is offline   Reply With Quote
Old 02-15-2009, 05:48 PM   #3
the BEST source for thin stainless rods that i have found are stainless steel arc welding rods. they are nice and straight, are a convenient length to work with, and once you knock the flux off of them, and give em a buff with some scotch-brite or polish, they are excellent for all kinds of RC building.
cipe is offline   Reply With Quote
Old 02-15-2009, 05:48 PM   #4
No i meant 5/32, actually 6/32 would be 3/16 right? Maybe 3/16 would work but i dont want it to have threads on it for looks. There was a guy on here making them but he's not making them any more. I have a 3mm die to put some threads on the end of the rod. I just don't want the hole shaft to have threads on it for better looks. Just don't know where to get it Lowes does'nt have it.
Old 02-15-2009, 06:20 PM   #5
i used 3mm allthread , traxxas ball ends and carbon fiber tube made real nice steerring links.
grrman is offline   Reply With Quote
Old 02-16-2009, 12:05 AM   #6
http://www.onlinemetals.com/
http://www.mcmaster.com/
dave m is offline   Reply With Quote
Old 02-16-2009, 01:34 AM   #7
http://www.speedymetals.com/pc-1085-...-annealed.aspx
http://www.speedymetals.com/pc-109-8...ess-steel.aspx
I buy alot from these guy's
Joat is offline   Reply With Quote
Old 02-16-2009, 01:41 AM   #8
You could use 6/32 threaded rod and traxxas 1942 rod ends. The cover the treards with some aluminum tubing or delrin tube.
2JSC is offline   Reply With Quote
