Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: MRC ESC and Motor!!!!!!!!!!!!!
Old 02-16-2009, 05:12 PM   #1
muddog27's Avatar
Default MRC ESC and Motor!!!!!!!!!!!!!
I have a MRC in the mail and I going to put a HS-5645MG and I wondering if I need to get a naw ESC????? If i do what should i get?????
muddog27 is offline   Reply With Quote
Old 02-16-2009, 05:35 PM   #2
JSN
The ESC is fine unless you want something better...up to you. You MAY have problems with that servo and stock ESC combo... some have some have not. What i did to be safe is wire up a Castle creations BEC(bout $24) and power the servo DIRECT from the BEC... by doing this the servo power demand(amps) come directly from the battery... not through the receiver power buss... the stock ESC just powers the receiver... this takes the servo power load off both the ESC and power buss of the receiver.
JSN is offline   Reply With Quote
Old 02-16-2009, 06:34 PM   #3
muddog27's Avatar
Thanks
