Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: Front battery/servo tray?
Old 02-18-2009, 02:03 PM   #1
Default Front battery/servo tray?
Does anybody make a pre-drilled ready mount front battery/servo tray?
I have rcbros rear plate, but I need one made for the front, thanks for any help
Shadill is offline   Reply With Quote
Old 02-18-2009, 02:05 PM   #2
Losi makes one, only for the small servo though. Make your own, cut piece of alum and use stock mount to drill holes.
fixed13 is offline   Reply With Quote
Old 02-18-2009, 02:11 PM   #3
Rock This
WrenchHead's Avatar
I use the Losi C/F battery/servo plate. I was going to make my own but my LHS had one and it was $10 so I opted for it. Works great with my mini LiPo battery. Have not had any issues with it and have been running it for a few months now.Not sure of the part #, but can get it for you if need be.CYA
WrenchHead is offline   Reply With Quote
Old 02-18-2009, 09:19 PM   #4
Default Tupperware
I just bought the Hitec HS-5645 servo (which is bigger then stock). I took an old tupperware and cut it to make a new servo plate, works great.
ukbulldog is offline   Reply With Quote
Old 02-18-2009, 09:23 PM   #5
Haha...tupperware,
willashcroft is offline   Reply With Quote
Old 02-18-2009, 10:02 PM   #6
Really?
montana.matt's Avatar
The Crawler Store makes one.... don't have any experience with it, though
https://www.tcscrawlers.com/TCS-Craw...h-p-17157.html
montana.matt is offline   Reply With Quote
Old 02-19-2009, 08:06 AM   #7
For that price, it's not even worth the time to make one, thanks
Old 02-19-2009, 03:30 PM   #8
I don't have any experience with that one either, I made mine so that I could mount a full size servo. I am not using as a battery mount though.
Old 02-19-2009, 04:58 PM   #9
I'm using the Losi plate and the losi small lipo with stock servo right now with no complaints. Planning on running the hitec 225mg at some point.
bigtim is offline   Reply With Quote
Old 02-20-2009, 12:53 AM   #10
is the hitec 225mg a direct bolt on? Sounds pretty good with 67oz tourque for this mini.
howard619 is offline   Reply With Quote
Old 02-20-2009, 11:47 AM   #11
I had one directly bolted on but found it was bad. Found it would turn only one direction. So just waiting for it to come back from Hitec. It did fit just fine.
Old 02-20-2009, 11:29 PM   #12
I'vew got that one, for some odd reason it had a couple extra holes drilled in it that happened to be in about the right places for a normal sized servo! I put a 645MG in it with Nitro 4-Tec servo mounts today at work (slow day, sales were good at least!)
BJoe is online now   Reply With Quote
