| | #1 |
| Back in the WATER! ![]() Join Date: Mar 2008 Location: Pacific Ocean
| I loved the Fubar Skeeter chassis for my Berg so much that I kept bugging MTHead to find out if an MRC version was coming. He was kind enough to send me an early prototype Mini Skeeter!!! Nice package ![]() Overlay. As you can see you have more shock and upper link mounting options. ![]() ![]() It’s the same great quality as the 2.2 version. I like the use of the matte Delrin as it doesn’t leave any fingerprints. ![]() ![]() In the middle of the build I made my first photo box. My cammera still sucks though. ![]() I've been using these Traxxas metal yokes and pede shafts for a while now without any issues. Even though the Yokes are too big for the outdrives, using a set screw on each side evenly tighted holds them on without issue. I did have to grind the tranny plate a little to make room for the bigger yoke. ![]() Up front I used the stock 3 link for now. This is what I was running with the stock chassis so for comparison purposes I don’t want to change anything yet. It will be 4 linked soon though. ![]() I was able to mount the rear uppers inside the chassis but ideally they would be in the lower hole. I hear a design change may be coming to accommodate this. ![]() I sure hope this is enough servo for this beast. ![]() Spaghetti? I really need a Tekin FXR. In this pic you can also see the shock mounted to the outside part of the axle tab. To prevent what is the weeker part of the tab from breaking, I place 1/4" delrin in the center and ran a longer screw all the way through to the beefier threaded tab on the axle. ![]() Because the Delrin skid is thicker than stock, John countersunk the holes enough so you can still use the stock screws for mounting the tranny. Nice touch. ![]() All complete. But I really want to try the new Losi shocks for this. These are the Mini LST shocks and I feel they are limiting the flex too much. Maybe soft springs on the rear will help but there still seams to be an overall travel issue. ![]() ![]() ![]() Oh yeah, almost forgot… ![]() As soon as I get some new shocks I will take this out to my favorite crawl spot and take some video... Last edited by dpdsurf; 02-21-2009 at 02:40 AM. |
| Sponsored Links | |
| | #2 |
| Linux Mint 10 ![]() Join Date: Mar 2008 Location: SSF
| Damn, that chassis looks sweet. |
| | #3 |
| NBRCC ![]() Join Date: Jan 2008 Location: Cotati
| Looks great! Can't wait to see it run. |
| | #4 |
| Axial Team Driver ![]() Join Date: Feb 2005 Location: OC
| Nice rig Dave. I didnt know your 2.2 was a skeeter! Fubar makes some nice products |
| | #5 | ||
| | #6 |
| Just having Fun Again ![]() Join Date: Apr 2006 Location: In your fridge stealing a beer
| Looks good you got alot more done than me. |
| | #7 |
| Pebble Pounder Join Date: Feb 2009 Location: johnson city
| very nice. what shocks are you running? |
| | #8 |
| Mr. Series Champ!!!! ![]() Join Date: Nov 2007 Location: CEN CAL
| subscribed |
| | #9 |
| Thanks, it was a pretty quick chassis swap out only as opposed to the nice parts you're accumulating. Thanks, they are Losi Mini LST shocks made by 3 Racing. They are not bad but I want to try something that has a little more stroke. They are 70mm eye to eye where Losi MRC shocks are 73mm eye to eye I believe. Thanks, made a little test run today. I'll have to get video next time. |
| | #10 |
| DOOH!!! ![]() Join Date: Feb 2007 Location: *
| Dang you work fast Dave!! I'm still cleaning the shop from making them.. The build is looking Awesome, may i suggest the Traxxas 2742X rodends though just incase you get into a wheelbase issue, they are the same length as the stock Losi but use 3mm hardware.. Loving the photo booth too.. |
| | #11 |
| | #12 | |
Can't wait to see it! | |
| | #13 |
| Pull the trigger on the vanquish wheels. The time they spend on machine time and finish is worth it. |
| | #14 |
| RCC Addict ![]() Join Date: Aug 2007 Location: Rohnert Park
| Dave: SWEET looking rig! Very nice build thread as well. Let me know if you need help finding an FXR or those 1.9 Vanquish rims (we gott'em in stock!) |
| | #15 | ||
The FXR is on the way, I'll talk to you next month about the wheels Jake, thanks. | ||
| | #16 |
| Well I got the shocks working much better with 65wt oil, cutting down the front springs and adding losi whites to the rear. ![]() ![]() ![]() I didn't have enough 2742X rod ends on hand so I just snipped 2mm off of these which got it right at 8.5" wheel base. ![]() Oh yeah, I forgot to show off my Eritex wheels with my good friend JeepinDoug's wheel weight mod. I'm running full weights front and rear with a full wrap on the inside of the fronts. Last edited by dpdsurf; 02-23-2009 at 08:21 PM. |
| | #17 |
| You'll love all the extra weight in the wheels. All that weight makes me feel so uneasy................ until I crawl it. You cut the front springs? Any special way? Compression springs like to have the last coils reduce helix (so to speak) to end at a flat surface. In these conditions it helps to keep the spring seated on the cup well. I just don't want to do it cuz I'm afraid the spring is going to always loose it's seat. EDIT - I see, you left the cut side up on the shock........at least on the driver's side Last edited by JeepinDoug; 02-23-2009 at 09:12 PM. |
| | #18 | |
| The extra weight seams to help keep it planted when hitting angles beyond it's articulation. Quote:
| | #19 |
| MTHead sent some real nice templates for these 4 link/servo/electronics mounts. The loose one on the right was my first one I made, it's a little off so I need to make another. ![]() The ESC and RX fit nice on it. The FXR on the way will fit even better. The battery will end up on the front one. Last edited by dpdsurf; 02-24-2009 at 09:19 PM. |
| | #20 |
| Rock This ![]() Join Date: Nov 2008 Location: Sunny Southwest Florida
| Nice,real nice. Keep em comin.CYA |
| Tags |
| dpdsurf |
| Thread Tools | |
| Display Modes | |
