| | #1 |
| Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
| Heres the specs: Nat V3 (thank you Jerry) HH mini torque master tekkin fx-r Hitec 645 Losi goodies (you can figure them out) And some other stuff I put together Once I get it out to the lake I will post up some more pics! Lovin this chassis already though, excellent work by Jerry |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Jan 2009 Location: Sandpoint
| for some reason those tubers just look like extra bars added to black mrc chassis. maybe if you took off the actual tuber part it would be a good chassis. good job on the truck and nice paint job |
| | #3 | |
| Pebble Pounder Join Date: Jan 2009 Location: SF
FYI to drvnbeing, you can actually get both the ESC and the receiver on the little metal tray inside the frame if you want to. One fits on top, the other on the bottom. It cleans up the look of the rear axle area., keeps everything nice and tight. Sweet rig BTW. Last edited by dave m; 02-21-2009 at 10:08 AM. | |
| | #4 | |
I kind of thought the same when I first saw this, but after getting this the chassis is actually a lot bigger than stock, shock holes are almost exactly where they were on the chassis I had fabricated. This is a very well thought out/designed chassis. Truth of the matter you could take the tuber of and put a shell back on if you wanted too. | |
| | #5 | |
Hey thanks for pointing out that plate, completely over looked doing that! Thanks! | |
| | #6 |
| | #7 |
| Hey I was wondering if I should run a BEC in conjunction with my setup here, any input or suggestions?? TIA |
| | #8 |
| Okay so i had to run my rig with a body at this weekends comp due to rain and this is how it turned out. This chassis is awesome I just mounted a couple of post on there and BAM had a body on it. |
| | #9 |
| Rock Stacker Join Date: Oct 2004 Location: Concord
| How do you like those tires? I'm running a nat v2 and was just wondering. |
| | #10 |
| | #11 |
| Thanks for your info. I'm torn between the flatirons, the bashers and the blue claws. I do kind of like the clerance of the flatirons. |
| Thread Tools | |
| Display Modes | |
