| | #1 |
| Quarry Creeper Join Date: Sep 2008 Location: Ukiah
| Has anyone besides me had trouble with the stock screws on the mounting bracket i know they're 1.5's. i already switched servo plates for a 645 but seriously these things pissed me off did anyone else have problems removing these scews? |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: Feb 2009 Location: Springtown
| Yes, they were a beating to remove. |
| | #3 |
| my dad and i racked our brains and figured out that we'd use this stuff (cant remember exactly the name) but my dad said it was basically "Liquid Grip" |
| | #4 |
| Pebble Pounder Join Date: Dec 2008 Location: Tomball, Tx
| you need a really sharp (new) screwdriver style driver. Don't even bother with an allen key. After a few remove/install times, i got fed up, drilled and tapped for 3mm screws. I also cut the countersinks in the servo mount plate a little deeper to accommodate the larger c-sunk screw heads. The upshot is the screws use a 2mm driver. Much better! I took the former servo plate mount screws, cut some countersinks into the chassis plates and used them to replace the lower link screws. smoothes out the chassis right there. For the other 2 screws on each side, use the leftover screws from the battery posts on the top plate. |
| | #5 |
| Quarry Creeper ![]() Join Date: Dec 2005 Location: Mechanicsville, VA
| Every 1.5 screw on the MRC is junk... ..yeah, thats all. Jon |
| | #6 |
| Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
| The front ones were not that bad, I had to dremel a slot in the rears and just use a flat head now...alot easier. The 1.5mm driver I bought last month is almost nothing after grinding the tip to use it everytime |
| | #7 |
| my dad and i werent gonna use the stock plate anymore. so cut it to sh*t with a plastic cutter and got the screws out with the mounting posts still intact and took the screws out. Whats up Losi whats with these dinky azz screws |
| | #8 |
| Pebble Pounder Join Date: Jul 2008 Location: Texas
| I hated removing mine... took me way to long... |
| | #9 |
| Rock Stacker Join Date: Feb 2009 Location: Hesperia
| | #10 |
| RCC Addict Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
| Never had a problem with the 1.5mm screws on mine:? |
| | #11 |
| Quarry Creeper Join Date: Nov 2007 Location: Northern
| I had one that would not come out. I ended up drilling the head off to remove the servo bracket and removing with vice-grips. I think the screws are stainless, too! I had a bunch of flat phillips machine screws that certainly took their place. A #1 screwdriver is by far better than a 1.5mm allen. |
| | #12 |
| Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
| try using a 1/16" hex wrench I had a bunch of trouble till I switched. |
| | #13 |
| RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
| Just go 3mm and never worry again. My MRC screws are in a landfill somewhere after I took them off only 1 time. |
| Thread Tools | |
| Display Modes | |
