| | #1 |
| RCC Addict ![]() Join Date: Apr 2008 Location: Old Hickory
| Well I got some new bling and had to test it out! I cant believe how much difference there is between stock tires and the g8 flat irons! My truck was going places that I would have never givin my stock set up a second look! I love the delron bent links also a great upgrade my truck took a couple of hard falls today and no problems! Thanks to RPP Hobby for the rims! Thanks to TCS for the flat iron's! Thanks to SAC Racing for the bent links! Got the hitech 645 from the LHS! These are great vendors to work with and I found em here!!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And YES it did make it up!!! |
| Sponsored Links | |
| | #2 |
| SCALE PERFORMANCE PARTS ![]() Join Date: Oct 2007 Location: College Station, TX
| Can you tell me how the Axial wheels compare to the Losi wheels in terms of width and backspacing? Do the Losi rings fit on the axial wheels? I have a custom set of lock rings for my losi wheels and I'm wondering if they would fit on the axial wheels... Last edited by Locked Up; 02-23-2009 at 04:47 PM. |
| | #3 | |
| Quarry Creeper Join Date: Sep 2008 Location: Ukiah
Are these tires any improvement over the bashers? | |
| | #4 |
| After haveing the axial wheels I will not go back to the stock losi rims. They look great and are just plain better. And the tires went on flawlessly. Much easier to add weight to also. Should I upgrade my stock motor without metal lockers or am I askin for carnage? |
| | #5 | |
| Gold Star Baby! ![]() Join Date: Aug 2008 Location: Gone 1.1 crawling
| | #6 |
| Thanks I was REALLY close to putting in a Losi INSANE 370 in her but I'll wait till the lockers show up. Too bad it wont be before the next comp. |
| | #7 |
| Newbie Join Date: Dec 2008 Location: Harrisburg
| I was wondering if you left the stock foams alone are if you cut them a little. Based on your test, what do you suggest? |
| | #8 | |
I may remove some of the memory foam in the future but I want to run it for awhile first plus get some tips from other guys with simmilar set ups. | |
| | #9 |
| Quarry Creeper ![]() Join Date: Oct 2008 Location: Stink Grove
| I have the axial BL i dont like the off set makes my rig to narrow I got those traxxas wide hexes |
| | #10 |
| Rock Crawler Join Date: Sep 2008 Location: PA
| I really want these tires! But Losi blue Claws/Bashers keep me from pulling the trigger and buying them! |
| | #11 |
| I play with TOY TRUCKS ![]() Join Date: Jun 2006 Location: Ukiah
| Cool Looks like the Van Halen paint scheme |
| | #12 | |
Also, is the width and backspacing the same as the Losi wheel? thanks | |
| | #13 | |
On the axial wheel the same measurement is 12mm. As far as the losi beadlock fitting on to the axail rim I would say nope here's some pictures. ![]() Note the thickness of the beadlock surface of the losi vs axial ![]() ![]() Losi...plastic Axial...Aluminum ![]() I put a screw though each beadlock the holes do not line up. Hope this helps. | |
| | #14 |
| Exactly what I was wanting to know for the rings. Thanks. So the backspacing is 1mm different. What about the width of the wheel itself? Last edited by Locked Up; 02-24-2009 at 09:26 AM. |
| | #15 |
| I wanted to say they are the same but I was too lazy to tear down 2 beadlock wheels to check just by spot checkin the axial may be a mm wider but not much they are pretty close! |
| | #16 |
| | #17 |
| Newbie Join Date: Mar 2008 Location: Wallingford, Conn.
| Hey SWEET RIG!!! Just wondering what the width is with the axial rims and those Flatirons is compared to stock. Thanks sick paint VH rules! |
| | #18 |
| | #19 |
| | #20 |
| Well last night I bit the bullet and ordered 4 Flat Irons and 4 Axial beadlocks like you have. I wasn't sure if I wanted to get Rock Claws or Bashers instead, but I found a great deal on Flat Irons and they were even cheaper than the Losi tires. I also wanted to get aluminum beadlocks, but just couldn't justify it yet. Do you have any weights on your Axial beadlocks? I'm trying to locate stick on weights locally, but I can't find them! |
| Thread Tools | |
| Display Modes | |
