| | #1 |
| Pebble Pounder Join Date: Aug 2008 Location: pine
| i just got my MRC last night and wile it was charging i took apart my car and made a back 3 link cover and i put the battery on the servo. i was wondering how much wait i should i put in my tires and I'm getting some flat irons for it soon, should i put my stock foams from my losi claws and put them in there or should i leave my stock foams in my losi claws and just cut them down. would that help my car out from flipping over? |
| Sponsored Links | |
| | #2 |
| Live,Eat,sleep RC ![]() Join Date: Nov 2005 Location: Oregon
| I'd run about 3-5oz in each front wheel. As for foams, the stock claws just aren't a great compound. Leave them as is and order up a set of blue compound claws or the new G8 Flat irons. |
| | #3 | |
| RCC Addict ![]() Join Date: Feb 2007 Location: LRC
| | #4 |
| now how does the tire stay on the bead lock becaue i dont want to glue it back on |
| | #5 |
| You will have to do the pvc mod ,I dont know if that is exactly what it is but people are taking some kind of plastic pipe and cutting it to width and sliding it over the wheel and drilling through the beadlock ring and tapping it and there you go you will have beadlocks .There is probably more to it than that so you might want to search and find it to make sure |
| | #6 |
| Gluing the tires on the stock wheels is very difficult to do in my opinion due to the section they give you to hold the tire on. The PVC mod is something like our Beadlock Spacers found here: http://rcbros.com/cart/Scripts/prodV...?idproduct=336 ABS plastic that slides over the rims and allows the outer rings to pinch the tire tight. Along with the link in the description you'll see a link for a how-to on how to go about the process. |
| | #7 |
| wut size is it? |
| | #8 |
| Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
| 2" inner diameter and 3/4" wide |
| | #9 |
| Pebble Pounder Join Date: Jan 2009 Location: Wichita
| I did the PVC mod this weekend. I ended up cutting them to .67 tho. That gave me a 1/16th of tire to squish in either bead ring. It made installation much easier too. If that's not enough to hold them, I'd be very surprised! Mike |
| | #10 |
| RCC Addict ![]() Join Date: Apr 2008 Location: Old Hickory
| Ok why no wieght in the rear I've read almost everything here and most people run 1/2 or less than the front. I get you want a heavy front. I tend to take a note when a HEAVY HITTER as yourself makes a setup tip. |
| | #11 |
| I to dont run weight in the rear either, wether its true or not, I feel that more weight on front creates a weight bias towards the front. From the theory of a stability triangle I want the front to be pushing itself downward as often as possible, having more weight on front and none in the rear creates this balance. Last edited by RcBro; 02-25-2009 at 04:31 PM. |
| | #12 | |
| Thread Tools | |
| Display Modes | |
