03-10-2009, 09:05 PM | #1 |
Quarry Creeper Join Date: Sep 2008 Location: Ukiah
| locker
Hi i just bought metal lockers and cvds and my locker cover on one side(cant remember which) wont budge at all the other side came off fine but the screws have broken a screwdriver what do i do?
03-10-2009, 09:22 PM | #2 |
Rock Crawler Join Date: Jun 2006 Location: LOMPOC
Make sure you have a nice new screwdriver for the task. Rich the losi guy said that you need a good driver and maybe use a little heat to break up the threadlock. If you have an adjustable soldering iron turn it all the way down and hold on the screw head for a short while then it should help come out.
03-11-2009, 01:13 PM | #3 |
Newbie Join Date: Jul 2008 Location: chandler AZ
you can always try the motor spray, light the locker on fire, let it burn out and that should help with the thread locker coming lose, good luck |
03-11-2009, 03:30 PM | #4 |
Quarry Creeper Join Date: Jan 2006 Location: ---EAST--TN---
I heated up a sharp pointed nail with a propane torch until it was pretty hot. Then put the tip right into the center of the screw and hold it for a couple seconds. That should loosen the threadlock. Also, the screwdriver I used was a #00 tip. The one I used was new, and had a good sharp tip. Every single screw on all three lockers came out easily using this method. |
03-11-2009, 03:42 PM | #5 |
okay thanks guys i can finally finish getting these in should i threadlock them in?
03-11-2009, 07:08 PM | #6 |
Yes but put only a tiny bit. The more you put on the more you will fight with if you need to take it apart.
03-11-2009, 09:29 PM | #7 |
how long will it be before the plastic starts to melt i dont want that to happen so....
03-11-2009, 10:19 PM | #8 |
oh,yeah, i got the HR aluminum ones and "broke" out the plastic. so just the gear w/ screws was there, sorry i didnt mention that
