Big Joe's MRC Comp Rig v4 Just wanted to share my updated 1.9 comp rig for HRCC. Losi Bronko Body Losi MRC axles w/ Losi steel lockers Losi Trans w/ Losi steel locker Losi Front Aluminum Cs, Knuckles and CVDs Losi Rear Aluminum lockouts Losi MRC shocks w/ 30w oil and 3/8" fuel tubing spacers Hitec HS-645MG Losi stock MRC motor, Mamba 25 ESC, 2s Lipo Lost Aluminum Bead Locks w/ weights DNA 1.9 Slingshot Chassis kit 8.5" Wheel Base 7.75" Track Width 2.5" belly clearance with Losi Rock Bashers 2.8" belly clearance with Proline Flat Irons Future mods will be a Holmes Hobbies TorqueMaster Mini and make a rear axle truss to bridge the aluminum lockouts in hopes to minimize bending the solid axles. A few photos of JoeWorks MRC v2.. Thanks for looking.. With the Flat Irons http://i280.photobucket.com/albums/k...ksMRCv2001.jpg http://i280.photobucket.com/albums/k...ksMRCv2003.jpg http://i280.photobucket.com/albums/k...ksMRCv2007.jpg With the Rock Bashers http://i280.photobucket.com/albums/k...ksMRCv2010.jpg http://i280.photobucket.com/albums/k...ksMRCv2016.jpg http://i280.photobucket.com/albums/k...ksMRCv2009.jpg Shoots.. |
Great looking rig Joe! 8) Looks like a total overhaul from your first comp rig. "thumbsup" So, how do you like the mini SS? Can't wait to see it in person. |
Looking Good Joe! Get some body off pics of that bad boy ;-) |
Bronco looks sick Joe. Have you run it yet? |
love the bronko body just wish it was crawler tuff i got mine trimed out more than yours & the tires still rub any issues with yours? |
As far as the Mini SS, performance wise I didn't have a chance to run it yet so no opinion there. But as a kit, I have a few small (in my opinion is small) issues when building it as follows. 1. My kit didn’t come with any instructions and if it wasn’t for other builds on this site, someone may have problems not knowing what goes where. I couldn’t even find any info on there web site also. But for some luck, I figured it out. I think. 2. My kit in my opinion was not complete due to having to the ball ends for upper links were not included and there where no indications on there web site or its packaging. I used ball ends from spare axial rod ends. 3. The two servo and upper link plate needed some modifications in order for it to work on my build. First I had to re-drill all the screw holes one size bigger in order for the MRC factory screws to fit and to countersink the three mounting holes so the factory screws can be used properly. I also had to drill and tap the upper link mounting holes to accommodate the axial rod ends. Other then my little issues, it all went together well. Quote:
http://i280.photobucket.com/albums/k...sMRCv2001a.jpg http://i280.photobucket.com/albums/k...sMRCv2001b.jpg http://i280.photobucket.com/albums/k...sMRCv2001c.jpg Quote:
With the Mini SS chassis and the body sitting as low as possible, the rear tires doesn’t rub the body and with the way the front fender opening sets back from the chassis, when full articulation and the wheel turned out, it looks like it rubs the fender well a little. Not sure until her maiden run to see what happens. Planning to shoe goo the fender well openings in hopes to protect them. Shoots.. |
Looks good Joe "thumbsup" Look forward to seeing this thing in person and hearing your thoughts on it. Does it still come with the clear skid plate? |
Shoots.. |
You taking her out tomorrow? Call me up. Jayvin & I need some practice too. Just got my mini Zero together. |
Was kewl to see this thing in person today! How did the run go today? |
What wheel wideners are those? I love the bronko body! |
Good looking build. Sorry to hear about the hardware mismatching. I have been reading posts for 6months now about this problem with the chassis and hardware provided. I would have thought that DNA would have fixed this issue by now. :-( |
Shoots.. |
The wideners was made for the AE RC18T to use standard 12mm touring car wheels. Note that its was not a direct bolt on. A few mods was needed for it to work. It had to be drill to fit axle shaft and the thickness cut down 1 mm so the slot for the pin gets shallower and when install, the lock nut will have proper thread depth. I also had to replace the stock axle shafts to front CVD and rear solid axle because they are a bit longer on the threaded side. Shoots.. |
Thanks.. Yeah wish they (DNA) provide more information and note somewhere on the packaging about it being not a complete kit or make it complete.. As far as the wholes on the servo plates being a bit small, I would think they would do some QC and check the items in the package.. Oh well.. its not my company.. I'm not the most machaniclly incline but got lucky on V2's build.. Shoots.. |
howzit joe works, i have the mini ss too. i thought it was pretty hard to work with to. i had to redrill a few holes to make it work. i ended up drilling 2 holes in the delrin chassis braces and mount my shocks to them in a little triangular set up. i actually had a hard time due to the rcbros shocks i'm running. i'm happy with the end result. by no means this is a beginner chassis. there is a gaurantee modification that need to be done to make it work. especially for all the different setups out there. i also had to trim about 1/8 of an inch off the top front links to bring my caster in check. hopefully i can gtg with you guyz. i already stripped my rear ring and pinion. so it's on order right now. cutlass is cutting down some panthers for me so gotta wait for that too. shoots den |
Did you have any torque twist issues with this setup? |
Yeah.. Its to bad about the 1.9 chassis kit.. Hope they fix the isues soon but as for me it was just a little set back and part of the fun of build is solving problums"thumbsup" Shoots.. |
Shoots.. |
On to v3.. Went back to the Losi Rock Bashers and did the SicksAreR steering mod without cutting the steering knukles using Dubro 2mm rod ends and 4-40 threaded rod and aluminum tubing.. Hope to see an improvement at this weekends GTG. http://i280.photobucket.com/albums/k...orksMRCv3b.jpg http://i280.photobucket.com/albums/k...WorksMRCv3.jpg I'm still thinking of swaping out the Mamba 25 and putting back the factory ESC.. The Mamba 25's drag brake wasn't holding during her maiden run.. Shoots.. |
